SOURCE: Sony Grand Wega 60" indicator lamp blinks 5X green then 6 red
It is unusually to see BOTH of these flash codes together. I have never seen them at the same time. A 5 flash is a lamp driver error, which is possibly related to your lamp failure. You may have to replace the lamp driver or "ballast" to correct this problem. The 6 flash is a power supply problem and more serious, as it will likely take a technician to narrow down exactly where the fault lies. It may be a thermal fuse open OR a failure in the power supply itself. What was the original symptom that caused you to replace the lamp? Did you use an original Sony lamp as a replacement?
SOURCE: sony KDF55XS955, 5X GREEN THEN 6X RED BLINKS, SCREEN BLACK
5 blinking lights IS the lamp board, part # 1-468-927-12
