I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
SOURCE: 1TB Western Digital External keeping system from booting up
You need to go into the BIOS of your computer and change the boot order of your computer. Your computer must be set to boot from your main hard drive only.
SOURCE: power cord replacement needed
Is the product still under warranty? You can try http://support.wdc.com/warranty/index_end.asp?lang=en which is the Western Digital Warranty Support pages.
SOURCE: i just changed laptops and now the western digital
you have to keep the usb plugged into the same one you had it in before than shut your computer down than turn it back on and click install now wizard that should help you...
SOURCE: Missing data on my western Digital My Book essential edition
check in your drive option run the disk tools
SOURCE: i haveProblems with Western Digital My Book
You would more than likely have to send it in and get it serviced. Or if you can find out if it is just the USB 2.0 cable, then just replace the cable.
