The HP slow issue can be caused by many many reasons such as outdated hardware, overload startup programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do these manually, try the hp speed up software to give a free & full scan of your slow HP PC to find & fix all possible issues. Meanwhile, upgrading hardware configuration (add RAM, change a new video card, larger-volume HDD etc) can be a fast yet effective way to improve your pc performance. But that won't be the most economical way, as you know you can't always afford to do that. Good luck!
Yes some memory will help to a point...check this out http://www.fixya.com/support/r9628027-get_little_speed_boost_windows
Poor performance could be down to a number of reason's but adding memory is usually good value.
you can visit http://www.crucial.com to find out what additional memory (if any) you can add to your machine and how much it will cost.
Also worth making sure your anti-virus is up to date, that you have a decent amount of free hard disk space (at least 1Gb), defrag your hard drive if possible and run a good anti-malware scan to make sure there isn't any dodgy processes hanging about....suggest downloading and running the free edition of MalwareBytes - http://www.malwarebytes.org/products/malwarebytes_free
I hope this helps and good luck! If you have more questions - ask away!
Please take the time to rate this answer
Many Thanks K.
