SOURCE: inkjet refills
hi,
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
SOURCE: HP Photosmart D7360
HP support decided it could not be repaired on line, agreed to replace it but found it was a few days out of waranty...so it is dead in the water. Probably not cost effective to repair it.
SOURCE: hp c7180 printer does not recognize new ink cartridge
be sure you removed tapes from cartridge.
Follow the instruction and reinstall new cart.
SOURCE: Says that I need ink even though I just replaced it
to resolve the issue please replace all the ink cartridges and clean the print heads and reinsert the cartridges and align the printer. Click here for instructions to replace the ink cartridges.
SOURCE: Ink Cartridge shown empty on HP 7780
How did you do the factory reset?
Take out all cartridges and heads then unplug for 30 minutes?
Plug back in and reseat all removed items?
If so you probably have a bad head.
You can order them through HP or Staples.
The heads have a very short life of 10,000 pages.
