1997 Oldsmobile Achieva Logo
Anonymous Posted on Sep 14, 2011
I ve broken 2 lugs off right rear wheel i removed tire wheel and brake cover tried to pull wheel with wheel puller it is not moving am i proceeding correctly or do i need a bigger hammer
Anonymous
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Sep 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
3879
Points
54
Why are you trying to pull the ( wheel ) . If you need to replace the 2 broken lugs then all you need to do id hammer them back thru the ( wheel ) and go get 2 new ones that match those broken ones and hammer them back in from the back side of the ( wheel )
3answers
How to remove rear wheel
Hi, I hope I can help with this.
You should only have to remove the lug nuts and the wheel and tire will be removed. If you removed the center wheel nut then it sounds like you are trying to remove the brake rotor. To remove the wheel the 5 or 6 lug nuts need to be removed. To remove the rear spare tire there is a plastic cover to remove which then has a key hole (locks for security). You will need to unlock this as well.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
2answers
How to adjust parking brake on 1993 chevy lumina ?
  • Adjustments
  1. Apply service brake pedal three times with a force of approximately 175 lbs.
  2. Fully apply and release parking brake three times. Full application may require two pedal strokes.
  3. Raise and support vehicle, then mark relationship between wheel and axle flange.
  4. Check parking brake pedal assembly for full release as follows:
    1. Turn ignition switch to On position.
    2. If ``Brake\'\' lamp is illuminated, operate manual brake release and pull downward on front parking brake cable to remove slack from pedal assembly.
  1. Remove rear wheel and tire assemblies, then install two lug nuts to retain each rotor assembly.
  2. If two parking brake levers on both calipers are not against lever stops on caliper housings, check for binding in rear cables and/or loosen cables at adjuster until both left and right levers are against their stops.
  3. Tighten parking brake cable at adjuster until either the left or right lever begins to move off the stop, then loosen adjustment until lever moves back barely touching stop.
  4. Operate parking brake several times to check adjustments. A firm pedal feel should be obtained by pumping pedal two full strokes and rear wheels should not rotate forward when parking brake is fully applied.
  5. Install wheel and tire assemblies, aligning marks made in step 3.
2helpful
Brake shoes on 1987 f250 460 1987 2 wheel drive how to replace
Lift the front of your Ford F-250 off of the ground using a jack and jack stands. Remove the wheels from the Ford with a lug nut wrench to prepare the truck for servicing. 2 Open the hood on the engine compartment and take the lid off of the master cylinder that bolts to the brake assister on the driver's side firewall.3 Remove the hex-head bolts on the back of the brake caliper with a socket. With the bolts removed, pull the caliper off of the Ford's brake rotor.4 Pull the old brake pads out of the caliper and discard them. Squeeze the brake piston back into the backside brake caliper with pliers, and then insert the new pads into the brake caliper.5 Pull the rotor cap cover off the middle of the rotor with a screwdriver and use a socket to remove the nut located behind the cover.6 Pull the rotor off of the wheel spindle.7 Remove the old wheel bearings from the brake rotor and insert them into the new rotor. If the old wheel bearings are worn, replace them with new bearings.8 Slide the new rotor onto the wheel spindle and secure it using a bolt and socket. After you tighten the bolt, press the cover back onto the rotor.9 Place the caliper on the rotor and secure it with a socket and hex-head bolts. 10 Duplicate the process on the passenger side of the F-250. 11 Close the master cylinder after putting the wheels back on the Ford and lowering it to the ground. Press on the brake pedal to seat the pads against the rotor
Replace the F-250's Rear Brakes 1 lift the rear of the Ford F-250 off the ground with a jack and jack stands. Remove the wheels from the Ford with a lug nut wrench.2 Place a strip of paint on the back of the brake drum and rear brake drum cover so you can position the brake drum orrectly when you put it back on. If you plan to install new brake drums on your Ford F-250, skip this step. 3 Place the brake drum puller on the brake drum and pull the drum from the wheel hub. The method for attaching the brake drum puller depends on the brake drum puller that you use. 4 Remove the springs that attach the brake shoes to the wheel hub by pulling them off with pliers.5 Lift the old brake shoes off of the wheel hub and place the new brake shoes on the wheel hub. Secure the new shoes with the springs.6 Pound the brake drum onto the axle hub with a rubber mallet.7 Duplicate the process on the passenger side of the Ford.8 Put the wheels back on the F-250, lower it to the ground and, then press on the brake pedal to seat the shoes against the brake drum.
1998 ford explorer 2 wheel drive rear wheel bearing replacement
what about it?
conventional axle or limited slip? Get axle code off door sticker.
SECTION 205-02: Rear Drive Axle/Differential - Ford 8.8-Inch Ring Gear 1998 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR Rear Wheel Bearing and Axle Shaft Oil Seal -4.0L SOHC and 4.0L EI, Conventional
Special Tool(s) swn~us~en~file=st1514a.gif~gen~ref.gif Axle Seal Replacer
T83T-1175-A swn~us~en~file=st1283a.gif~gen~ref.gif Axle Wheel Bearing Puller
T83T-1225-A swn~us~en~file=st1322a.gif~gen~ref.gif Axle Wheel Bearing Replacer
T83T-1225-B swn~us~en~file=st1326a.gif~gen~ref.gif Driver Handle
T80T-4000-W swn~us~en~file=st1185a.gif~gen~ref.gif Impact Slide Hammer
T50T-100-A
Removal
  1. Remove the axle shaft; refer to Axle Shaft in this section.
Axle Shaft Removal
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
    Loosen the lug nuts (1012).
    1. Remove the center cap.
    1. With the weight of the vehicle on the wheels, loosen the lug nuts.
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
    1. Remove the lug nuts.
  1. Remove the axle housing cover (4033).
    1. Loosen the axle housing cover bolts (4346) and drain the rear axle (4001).
    1. Remove the axle housing cover bolts.
    1. Remove the axle housing cover.
  1. Remove the rear disc brake rotors (2C026); refer to Section 206-04 .
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-rings in the U-washer grooves.
    Remove the U-washers (4N237).
    1. Push the axle shafts inboard.
    1. Remove the U-washers.
  1. Reinstall the differential pinion shaft.
    1. Install the differential pinion shaft.
    1. Install the differential pinion shaft lock bolt finger-tight.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal (1177).
    Remove the two axle shafts.
Installation
  1. Lubricate the lip of the inner wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal.
    Install the two axle shafts.
    Install the U-washers.
    1. Position the two U-washers on the button end of the axle shafts.
    1. Pull the axle shafts outward.
    1. Align the hole in the differential pinion shaft with the differential pinion shaft lock bolt hole.
    1. Install the differential pinion shaft lock bolt.
  1. Install the rear disc brake rotors; refer to Section 206-04 .
  1. Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant; refer to Axle Housing Cover in this section.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control.
    Clean the wheel hub and mounting surfaces.
  1. Install the tire and wheel assembly.
    1. Position the tire and wheel assembly.
    1. Install the lug nuts and lower the vehicle.
    1. Tighten the lug nuts.
    1. Install the center cap.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time.
    NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris.
    Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
Installation
  1. Lubricate the new rear wheel bearing.
    1. Use Thermally Stable Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Use Axle Wheel Bearing Replacer with Driver Handle to install the rear wheel bearing.
  1. Lubricate the lip of the new axle shaft oil seal.
  1. Use Axle Seal Replacer with Driver Handle to install the axle shaft oil seal.
  1. Install the axle shaft; refer to Axle Shaft in this section.
5helpful
Replace brake pads on 2007 vw polo
Park the polo on level ground, turn the engine off and apply the parking brake. Pull the hood release handle and move to the front of the car.
Lift the hood and remove the master cylinder. Remove one-half of the brake fluid inside the reservoir with a syringe.
Loosen the lug nuts on the rear wheels with a tire iron. Place the jack beneath the frame at the back of the Volkswagen and lift the back tires off the ground. Rest the rear axles of the Volkswagen on two jack stands. Remove the lug nuts and take the rear wheels off.
Reach behind the brake caliper to locate the caliper mounting pins. Remove the pins with a 12 mm socket and ratchet. Lift the caliper from the brake rotor and suspend it above the wheel assembly with a bungee cord or wire coat hanger.
Remove the rear brake pads from the slots in the caliper bridge. Inspect the caliper bridge and rotor for damage and significant wear. Replace the rotor if it is warped or badly scored. Scoring of the rotors can lead to break failure and will prematurely wear the new brake pads. Place new brake pads into the slots of the caliper bridge.
Attach the piston depression tool to the caliper. The tool will fit over the back side of the caliper and against the piston inside. Twist the tool's handle to force the piston into the side of the rear caliper. Remove the tool once the caliper piston is totally depressed within the caliper.
Replace the caliper onto the caliper bridge and screw in the caliber mounting pens by hand. Replace the rear wheel onto the wheel bolt and screw on the lug nuts.
Repeat the process for the other side of the rear of the polo. Lift the rear end of the vehicle with the jack and remove the jack stands. Lower the rear tires to the ground and tighten the lug nuts with a lug wrench.
Return to the engine compartment. Remove the master cylinder cap and check the level of brake fluid. Place a funnel into the container and fill the reservoir with brake fluid as needed.
3helpful
How do you change a wheel seal on a mercury mountaneer 1998 rear end
Axle Vent
NOTE: If the vent cannot be cleared, it must be installed new.
A plugged vent will cause excessive seal lip wear due to internal pressure buildup. If a leak occurs, check the vent. Make sure the vent hose is not kinked. Remove the hose from the vent nipple and clear the hose of any foreign material. While the hose is removed, pass a length of mechanics wire or a small diameter Allen wrench in and out of the vent to clean it. Connect the hose when done. The vent is located on the drivers side top of axle housing.
If you plan on doing most repairs yourself I would suggest buying a Haynes or Chilton manual for your particular vehicle. Or there are some data disks on e.bay($12-$15) For a cost of under $25, you can almost do any repair yourself with these manuals.Also there are online manuals like the site called ALLDATA where guides can be viewed for a fee. All these solutions will save you time and money, and give peace of mind over correct repairs. I can post you some procedures here also.
  1. CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
  2. Loosen the lug nuts (1012).
  3. Remove the center cap.
  4. With the weight of the vehicle on the wheels, loosen the lug nuts Raise and support the vehicle. .Remove the wheel and tire assembly.
  5. Remove the lug nuts.
  6. Remove the wheel and tire assembly. Remove the axle housing cover (4033).
7.Remove the rear disc brake rotors You will have to remove the brake caliper to get rotor off.
8. CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
9.
1.Remove the differential pinion shaft lock bolt. 2.Remove the differential pinion shaft. 4fd1df0.gif 10.CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Remove the U-washers (4N237).
  2. Remove the U-washers.
    11.Reinstall the differential pinion shaft.
      12.CAUTION: Do not damage the inner wheel bearing oil seal (1177). Remove the two axle shafts. 1848771.gif
CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time. NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris. Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
0ffed5b.gifAxle bearing puller end..
Installation
  1. CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  2. Remove the differential pinion shaft.
  3. Remove the differential pinion shaft lock bolt.
  4. Remove the differential pinion shaft.
    CAUTION: Do not damage the inner wheel bearing oil seal. Install the two axle shafts. CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Install the U-washers.
                                                            Install the rear disc brake rotors; Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant
                                                            WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control. Clean the wheel hub and mounting surfaces. Install the tire and wheel assembly.
                                                            Position the tire and wheel assembly. Install the lug nuts and lower the vehicle. Tighten the lug nuts. Install the center cap. 6a78fd6.gif WHEW Hope this can help you
                                                            2helpful
                                                            2answers
                                                            Broken rear wheel stud how do i repair it
                                                            The stud has to be hammered out if you don't have the tools to do this then I suggest you take it to a tire shop they don't charge much. depending if it's front wheel or rear wheel drive will determine what has to be done. If it's a rear axle they will remove the tire and drum and knock out the old one with a hammer and punch and replace it with a new one same size, they can hammer it back in our use washers to pull it into place this is the same on the front wheel. You will need to measure the bolt to get the right length and width. tire shop will have the stud you need.
                                                            How do i take off the rear wheels
                                                            take off the five lug nuts on the wheel,first loosen lugs before taking off the ground, once it jacked up proceed to remove the lugs and pull tire to you and that should be it
                                                            I’m happy to assist further over the phone at https://www.6ya.com/expert/john_2c7bb9c157d0baa8
                                                            2answers
                                                            Cant remove wheel hub
                                                            here is procedure
                                                            Section 04-01: Suspension and Wheel Hubs, Front 1996 Taurus, Sable Workshop Manual
                                                            REMOVAL AND INSTALLATION Wheel Hub Bolt Removal
                                                            1. Raise vehicle on hoist.
                                                            1. Remove wheel and tire assembly. Refer to Section 04-04 .
                                                            1. Remove disc brake caliper (2B120), and front disc brake rotor (1125). Refer to Section 06-03 .
                                                            Brake Shoe and Lining Removal
                                                            1. Remove brake master cylinder filler cap (2162). Check fluid level in brake master cylinder reservoir (2K478). Remove brake fluid until brake master cylinder reservoir is half full. Discard removed fluid.
                                                            1. Raise vehicle on hoist. Refer to Section 00-02 .
                                                            1. Remove wheel and tire assembly from front disc brake rotor mounting face. Use care to avoid damage or interference with disc brake caliper (2B120), front disc brake rotor shield (2K004) or front wheel knuckle (3K185).
                                                            1. Remove rear brake pin retainers (2N386). ( I think it is a T 40 torx bit you need)
                                                            1. NOTE: It is not necessary to disconnect hydraulic connections.
                                                              Lift disc brake caliper from front disc brake caliper anchor plate (2B292) and front disc brake rotor (1125). Do not pry directly against metal caliper piston or damage will occur.
                                                            1. Position disc brake caliper out of the way and support with wire to avoid damaging the disc brake caliper and front brake hose (2078).
                                                            1. Remove outer brake shoe and lining (2001) assembly from front disc brake caliper anchor plate.
                                                            1. Remove inner brake shoe and lining assembly.
                                                            1. Position lug bolt (1107) to clear front wheel knuckle (3K185).
                                                            1. Remove lug bolt from wheel hub (1104).
                                                            Installation
                                                            1. Install lug bolt into wheel hub.
                                                            1. Using a lug nut (1012), seat wheel hub bolt into wheel hub.
                                                            1. Install front disc brake rotor and disc brake caliper. Refer to Section 06-03 .
                                                            1. Install wheel and tire assembly. Tighten lug nut to 115-142Nm (85-104 lb-ft).
                                                            2answers
                                                            Broken lug bolt
                                                            Easy. Take wheel and tire off, and remove the brake drum, if it has drum brakes. With a hammer, hit the broken stud until it pops out. Slide the new stud into the hole, and, using some thick washers, screw the lugnut onto the new stud, over the washers. Tighten it until the stud is pulled all of the way in. Easier done with an air wrench, however.
                                                            Top Oldsmobile Experts
                                                            ZJ Limited
                                                            ZJ Limited
                                                            Thomas Perkins
                                                            Thomas Perkins
                                                            john h
                                                            Are you an Oldsmobile Expert? Answer questions, earn points and help others
