Try removing all the speaker and the HDMI connections; then use a headphone to listen to music from the tuner or a CD in stereo mode. Better in direct mode. If you hear your music correctly the receiver could be working correctly. If no music is heard, you may need to have it repaired professionally.
If you can hear music, connect the main FL & FR speakers and verify you can hear music that way, without the headphone connected.
If you can hear music that way, connect the center and rears. Try a mode that uses all channels to verify all sound channels are working.
Then, and only then start adding your HDMI connections.
Good luck
This is an old board. Have you tried your mic on another system to determine if it's not the problem? If so it could be the 1 x line-in / line-out / mic port is bad. Try switching your mic to a usb port.
Mic to Mixer, and Mixer to Laptop? Or is your mic connected directly to your laptop?
To do this properly, you will need a secondary audio input device of some kind that accepts line level input. Microphone inputs are intended for low level signals, and are not going to accept the input form a mixer properly. (you can get it to work, but it will generally be distorted)
There are various USB or PCMCIA audio input card options that aren't too expensive. Once you have that, you would need to route your music and microphone through your mixer, and the output of the mixer to your audio input device.
My understanding is that a webcam is only a webcam not a webcam+mic (mic=microphone for sound to be input) unless your webcam has video and sound capabilities.
1. get a mic
2. if you webcam is supposed to be also a mic, (I have yet to see one of those myself) you should hook up the connector for the microphone (usually a a red trs plug/connector) to your pc.
3. make sure your have run the video/sound wizard of your instant message application to test your video, mic and speakers. (to see, talk and be heard and hear what the others are saying)
are you trying to hear what the other person is saying when having a video conversation?
1. check your speakers are properly connected, powered and turned on.
2. check your speakers (and mic aswell) are not muted (check your speaker icon on the system tray and check your volume controls by doing right and/or left click on the speaker icon on the system tray.
4. make sure your sound adapter's drivers are installed and your device is working properly (check device manager by going to start>run> type devmgmt.msc the press enter and make sure that under sounds you don't have any ? (no drivers) or ! driver problem for your sound adapter.
HAI,AMP WORKS FINE , CONNACT ANY OTHER TO AMP(CD,DVD,COMPUTER,MOBILE,TV) IN BACKSIDE INAUDIO OR PRE_AMP .THEN SELECT PLAYER TO IN MODE YOU HAVE INSAERTED.THE SOUND IS OK
Happy Holidays Fredonna
Well, easy task, just put a music CD, on system and if you got an headphones, put in the green connector on your sound card, pop up the PC volume, and see if you heard sound, if you do, heard sound then the problem is your speakers. if don't is your sound card.
good luck
