If your computer is not properly authenticated to your wireless router or if DHCP is turned off in the router an invalid address or (windows auto configure address of 169.x.x.x) may occur since windows can not find a DHCP server, it assigns its own default address space to your PC.
1. If your PC is connected via wireless make sure you input the correct wep / wpa or wpa2 password.
2. If your PC is connected via cable reboot the router and see if it gets a valid address. If it still doesn't, you may need to reset the router by pressing and holding the reset for min 5 seconds. You may have DHCP disabled which is causing this issue so resetting the router will re-enable that.
Do you have more then one PC connected to your network? Do they all get 169 addresses or just one? If just one has this issue then it could be the network card (try removing it from device manager and reboot the PC so it finds it again and reconfigures it) IF the PC is connected via cable, try another cable. Make sure the PC is connected to a LAN port not a WAN port.
If resetting the router and everything else does nothing, you may need to replace the router.
Chris
