Question about Crown XTi 4000 Amplifier
Have Peavey sp4 cabinets. Am burning out high freq drivers like mad. Did not start until I wired in the xti 4000. usually happens when I get within two feet of back of speakers. Very shrill brief sound and high frequency drivers burn out. Also blows thermister on Peavey crossover and sometimes fuse.
    Brigadier General:
  • 8,546 Answers
If you're using a microphone it's feedback, duh.
How to Eliminate Feedback
http://www.mediacollege.com/audio/howto/feedback.html
Posted on Sep 14, 2011
Anonymous
SOURCE:
Blown fuse
It's not a fuse it is a lamp... to insure that you have the proper replacement, I suggest reordering from Peavey.
Dec 10, 2013 | Peavey SP4 2-Way PA Cabinet (2000 Watts,...
Sp4 blown fuse
It's not a fuse, it is a lamp and I suggest ordering replacements directly from Peavey.
Wiring diagram for peavey sp4g
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Feb 07, 2013 | Peavey SP4 2-Way PA Cabinet (2000 Watts,...
HOW TO CONNECT THE SPEAKERS
What type of speakers r they and what do u want them hooked up to?
Dec 16, 2011 | Peavey SP4 2-Way PA Cabinet (2000 Watts,...
I need a color coded wiring diagram for a peavey PV115 speaker cabinet.
Usually the colors you will find are red and black pair and yellow and white... USUALLY the red/blk pair go to the tweeter horn with red going to the + lead of the horn drivers. Usually the yellow/white pair go to the woofer with the white going to the + lead of the woofer in Peavey speakers... HOWEVER you never know if someone has rewired the cabinet so going by colors is NOT the best way to go... This should have the "soundgard" circuit in it and the lead that goes throught the lamp and resistor that is NOT connected to the inout jack is the TWEETER + lead. The pair that connects to the inout jack DIRECTELY is the woofer leads and the TIP connection of a 1/4 inch jack is the + woofer lead. Verifying these connections is the best method.
Aug 15, 2011 | Peavey PV 115 Speaker PA Passive
Crossover blow drivers.How can i get the part for thecrossover that has copper wire wraped on a piece of metal.What's it called? a coil or what.All i know is it keep the driver playing and keeps it from...
Hello iwelch1194:
The thing you are describing is called a choke or a ferrite crossover coil.
This site might have what your looking for:
"CLICK HERE"
That is there ferrite page. If you need something a little different just search their site. You will also need to know the COIL VALUE and wire size which should be labeled on your old coil in order to replace it with something compatible. Coils are rated in millihenrys (mH).
If this helped just click the thumbs up.
Your FixYa team member, Peter N.
Mar 26, 2011 | Peavey SP4 2-Way PA Cabinet (2000 Watts,...
I have a new peavey sp4 speakers and blown up my HF, I NEED HELP OF HOW TO OPEN THE FRONT NET OF THE CABINETS SO THAT I CAN UNSCREW THE HORN?
This is based on MOST cabinets like this: First look for any small screws which are usually through the grille near the top and bottom that retain the grille. When those are removed, one has to pry the grille out of the grooves at the side by dishing the grill outward at the center so edges come inward. There often is a "U" shaped rubber strip along the edges that will need to be put back on before grille is dished and put back.
Note that SOME speakers have a fuse or a polyfuse to protect them from excessive current. If yours do not, consider puttin in polyfuses to protect them. They are available from Digikey.com.
Calculate the hold current based on the pwer rating and impedance. Take the square root of the rated power of the HF divided by the impedance and choose aa polyfuse that will hold that current and one that will standoff the peak voltage of your amps. Calculate that voltage as the square root of the max power of your amp divided by the LOWEST impedance allowed for the amp.
http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=US&WT.z_homepage_link=hp_go_button&KeyWords=polyfuse
Set the filter to search for "Radial" type package and find suitable rating in the list that comes up.
Jan 09, 2011 | Peavey SP4 2-Way PA Cabinet (2000 Watts,...
Where can I get peavey replacement parts for sp4 speakers? Need to replace the internal board.
The internal board is the crossover. Your best bet is to contact Peavey directly. Call them up and select the service department. You can purchase parts directly from them. Have both the model (SP4) and serial number. Because the series has been around for a while, there are slight differences in the crossovers (may not be the case for the SP4, bt was for the SP2 series). The serial number will incidate the "run" and insure that you get the proper parts.
Dan
Feb 23, 2010 | Audio Players & Recorders
Peavey impulse 1015 horn cuts in and out
If the horn cuts out after some usage ...then its probably the limiter lamp that is gone .... the limiter lamp is switched into circuit once the " polyswitch " gets hot .... so at first the horn works ...then when the limiter lamp is switched in ...nothing !
its just a standard 12volt car tail light lamp ...let me know if this helps
Jul 27, 2008 | Peavey CH1 Speaker
Peavey PV215 Speakers
LIGHT IS PART OF SPEAKER PROTECTION CIRCUIT,CAN BLOW,MINE DID TO PROTECT HIGH FREQ DRIVER
Nov 10, 2007 | Peavey CH1 Speaker
Crown XTi 4000 Amplifier Logo
290 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
