Technics DV290 Hi. I am having the same problem with the length of the flat cables. Can you let me know how you solved this issue as no one does extention cables My email is dselby(at)live.com Thanks
Hi, i have the same problem with the flat cables. i want to put my stereo side by side, but the cables are too short. can you let me no how to fix this problem Thanx julieHi, i have the same problem with the flat cables. i want to put my stereo side by side, but the cables are too short. can you let me no how to fix this problem Thanx julie
You can't post conmments that contain an email address.
i am trying to do same thing - i suggest connect ps3 via optical cable to hi fi red/ white cables via a optical/ rca adaptor, the ps3 is connected to tv via hdmi so play dvd via ps3 sound will play through hi fi - but remember dont need the yellow dvd cable from hifi dvd player to tv any more as you will be using the ps3 as a dvd player instead
ION has just released a turntable that connect via USB! You can now play your lp's on anything that accepts usb cables. It is available at Bed, Bath, and Beyond. Also, there are many various turntables available that connect via RCA cable. Bet Buy and Circuit City both carry mdels that will hook to your unit via RCA cable. They have some models on sale at times for under $90 bucks! Thanks for using FixYa! And don't forget to rate my solutuion! Good luck, and Happy listenng!
Hi mkoles111,
I have a copy of what you need which I downloaded recently. It is in pdf format and is about 2.2mb. Let me know if you still need it and I will forward to you.
Regards
topgunner
I'm currently working on a solution fot this problem and will post my results as soon as I succeed. I have got the ribbon cable but having trouble getting terminal that matches the back of the system.
Hope to have some news soon after the weekend
regards
topgunner
I'm currently working on a solution fot this problem and will post my results as soon as I succeed. I have got the ribbon cable but having trouble getting terminal that matches the back of the system. Hope to have some news soon after the weekend regards topgunner
You will never find those connectors, as they come with the ribbon cable, which is long discontinued. Rather than that approach, take the easy route. Just cut the ribbon in any place that you need the extension, add in your new ribbon cable, and heat shrink each and ever wire.
i have the same problem with lack flat of cable length on the DV 290 system
i am having the same problem with the lack of flat cables could you please help
email [email protected]
