I dont have a manual with my paramount night vision. how do you operate it. i can get a red light but thats all.
Hello, You should have two switches, one for on/off and the other for IR intensifier (red). There should be or not two LED one green to indicate on/off--no green LED it off, if the green LED glows green it on. The same with IR luminator, red is glowing the IR is on, if not glowing red, it off.
Make sure you have new batteries and make sure that the polaity is correct---positive +,
negative -.
Push the on button, if you push the right button the green LED will glow, then push IR button. Put you hand in front of the monocular and see if there is a red glow on the palm of you hand, if there is then the IR is on. Never look into the IR lens. Now you can look through the eye piece.
Now, if there no green tent inside of the monocular then there are other problems with you NV devise.
Never, and I mean NEVER look at bright light at night or in the daylight. This will destroy the image tube. That is one reason why they are call night vision....Only for viewing in the dark. stewbison
