If it's an LCD projector, and the menus are yellow too, then one of the UV filters has failed. It's usually the blue one which is why the picture is yellow.
At this point the projector is toast. The cost of replacing the UV filter and the damaged blue panel will be more than the projector is worth.
Could be one of two problems. How old is the machine? If one of your LCD filters inside the machine has burned up it will show yellow. Common on SL4U. It starts with a yellow circle. If not that then most likely a bad VGA cable. If you have it hooked up that way.
From my experience, the projector bulb has most likely received a blemish of some kind from something such as accumulated dust on the front, to a fingerprint from where it has been handled by someone replacing it.
This yellow tinge then occurs when the blemish is burned onto the surface of the bulb.
In my opinion, unfortunately, you may need to get a new bulb.
Hope this helps!
The projector's lamp cover might not be securly on or you might need a new one, or the projector has blown a fuse that can be replaced other wise it could be your projector but be sure to contact your sony dealer first.
I had one with the same issue. After checking and rechecking the projector, I found that there was a lose conection between the CPU and the RGB output connection. It's really touchy.
I can't imagine a setting that would cause this - It sound more like some sort of fault with the projector's blue LCD panel. (The image is created from a mix of red, green and blue light. If you loose the blue, everything will look yellow.)
Is it capable of showing any shades of blue?
Using any graphics or photo-editing software, create a solid blue image (R=0, G=0, B=255 in your colour settings) and if possible, display this full-screen. Is there any output from the projector at all when you do?
If not, it sounds like it need a professional repair.
