Sorry, but the fx-115ES can only display square roots in radical form. Cube roots are beyond its symbolic capabilities and will always be in decimal form.
For cube roots, use the cube-root function in the MATH menu. For example, to calculate the cube root of 8, press MATH 4 8 =
For other roots (including cube root), use the xth-root function in the MATH menu. For example, to calculate the fifth root of 32, press 5 MATH 4 3 2 =
You can calculate cube roots by using the cube root function (the 2nd-shift of the 0 key). You can calculate arbitrary roots by using the x-root function (the 2nd-shift of the y^x key, just above the divide key).
What we call roots: square, cube ,fourth roots, etc. can be shown in algebra to be equiavlent to powers with fractionary exponents where numerator is 1 and denomonator an integer. square root of a = a to the power 1/2 cube root of a = a to the power 1/3 n-th root of a = a raised to the power 1/n, n integer different from 0.
How to use calculator to calculate cube root?
If you do not have a specific (shortcut) key for it you use the key to raise to an arbitrary power [^ ], sometimes shown as [x^y]. The exponent will be 1/3. Do not replace 1/3 by its decimal approximate.
There is a way to do it. I believe you go into "complex" or "math" buttons. These buttons are yellow on the calculator. Therefore, to access them you must hit "2nd" then the button.
Better yet, you can also get around this dilemma another way. You can enter "the cubed root of x" by raising x to 1/3.
For example the cubed root of x = x^(1/3). It is best to place parentheses around 1/3 so the calculator knows exactly what you mean.
Another example, the "cubed root of (x + 1)" can be entered by:
(x+1)^(1/3) Note the parenteses around both (x+1) and (1/3). This applies if the radical cover both "x" and "1".
