Outdated Adobe Acrobat Reader
Damaged PDF files.
PDF files with a virus.
Unsupported file type.
Damaged Adobe Reader.
PDF files created using non-Adobe programs.
Check and install Adobe Acrobat Reader.
Regards,
Will
Unable opening pdf files must be document corruption if it's true I should suggest you PDF Fix Toolbox to repair pdf files
Download pdf file from your email then, save to USB flash drive. Install pdf installer. download from google and install. After installing try to insert ur USB flash drive and open your pdf file.
SOURCE: Hi. I need ACRORD32.EXE to open pdf files I
some one with the newer version could open them then save them in some other format, than email them back to you, or possably convert them to an older format for you to open them.
also with the newest version of inter net explorer you shoud be able to open it on line with explorer, than save it to the version that you have.
SOURCE: when emailing files receiver can't open in current
no, depending on what type of program you used, there should be a viewer available for free download for your receivers to open.
EX: MS Word documents download is http://www.microsoft.com/downloads/details.aspx?FamilyID=3657ce88-7cfa-457a-9aec-f4f827f20cac&displaylang=en
If other applications, go to their sites and search for viewer
SOURCE: how can I open XLSs files that have been sent to
XLS files are Microsoft Excel spreadsheets. If you don't have MS Office or Excel installed on your computer, Microsoft has a viewer you can download. You can't make any changes to the file, but you'll be able to see what you have been sent. Here's the page at MS where you can find information and the download link for the viewer.
PDF files open with Adobe Reader which is something completely different.
Testimonial: "it has workrd thankyou"
