Computers & Internet Logo
Posted on Sep 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ati radeon 5450 when i am putting it in my computer my PC won't boot,... it shows power but will restart automatically,.. i have 500w morrLogic power supply,.. i also tried my old gt 7300 ddr-2,.. and it works,... my problem is that how is that my 5450 won't work >_<
Steve
Level 3:
  • Master 3,290 Answers
  • Posted on Sep 13, 2011
Steve
Master
Level 3:
Answers
3290
Questions
Helped
1127991
Points
12184
Many flavors of this video card from various manufacturers have different configurations - most important is the auxiliary power connector that appears on the edge of many of these cards. If your ATI has such a connector, it must be connected to the PSU. The MoBo bus can not supply the required power via traces on the board. If connected and it doesn't work - it may be a power supply problem.
While your 500 Watt power supply unit (PSU) is more than the 400 Watt minimum requirement, but depending on its efficiency and your system configuration, may still be on the "weak" side. Your particular PSU is not a certified type. ATI recommends using certified PSU's on this list. You could probably get away without using one of those expensive PSU if you got one with a little more "umpph" to it, say a 600 watt or more rated type. The 500 watts unit you currently have may be "just a little too close" with your PC's configuration.
I hope this helps & good luck!
Hp dc 7900 problems when i connect ati radeon hd 5450
you must see if have compatibility. You can go www8.hp.com and get support via ONLINE chat, and ask about this subject.
God bless you
1helpful
Hp 7900 usp make problems when i connect ati radeon hd 5450
your hp only has a 350 watt power supply, you need at least 400 watt, preferably 450 - 500 watt.
Trouble with install second video card HD 5450 to emachines t6532
Unclear of your statement. (More like run-on sentence)
Problem heading statement reads,
"trouble with install second video card HD5450 TO eMachines T6532"
Need clarification
The eMachines T6532 Desktop PC uses an MSI MS-7207 motherboard.
Also known as the MSI K8NGM2-L,
http://www.msi.com/product/mb/K8NGM2-FID--IL--L.html
(Click on photo for a better image)
Has one long white PCI Express x16 slot. (Expansion Slot)
Only uses one graphics card at a time, will Not use two.
[Graphics card / Video card. Same/same]
Therefore I surmise you are not referring to adding a Second graphics card, but are referring to;
A) This is the second time you have added a graphics card.
Or,
B) This is the second ATI Radeon HD5450 graphics card.
Had one before. Removed it, and are using a new one.
Or,
C) This is the second time you have added a graphics card.
It is not an ATI Radeon HD5450 like the old one is.
Know this;
1) You can ONLY use the OnBoard (Integrated) graphics,
OR the graphics card.
You CANNOT use both.
When using a graphics card the monitor is plugged into it.
You cannot plug into the onboard graphics of the motherboard, with it installed in the computer.
Said differently;
With the graphics card physically installed in the computer, you cannot just unplug the monitor from the graphics card; and plug it into the OnBoard graphics of the motherboard.
[Also; Computer on, you CANNOT unplug a monitor, and plug it back in.
This = NO ]
2) Driver: Small piece of software that allows the Operating System to communicate with a device.
The device is the graphics card.
The version of Windows operating system was not stated.
Did you install the software from the Installation Disk? (CD/DVD)
Has the drivers on it, and the user interface software.
User interface software for an ATI graphics card, is Catalyst Control Center.
(Just to note; I'm using a Powercolor Radeon HD5450 graphics card, right now.
I'm using dual monitors.
HP 2009M - 20 inch widescreen LCD monitor, and an RCA L26HD31 HDTV as the main monitor. (26 inch HDTV)
They work GREAT! ]
(It is an ATI Radeon HD5450 graphics card just like yours, IF yours has 1GB of graphics memory.
Doesn't matter what graphics card manufacturer, makes that HD5450, it is still an ATI (AMD) design.
Powercolor, VisionTek, Sapphire, Diamond Multimedia, Mickey Mouse, or Goofy. It is still an ATI graphics card )
The ATI Radeon HD5450 graphics card, has to have a MINIMUM power requirement of 350 Watts.
Does your power supply have 350 Watts or more?
If it is the original power supply, the answer is NO.
Back then power supply manufacturers were 'fudging' the true maximum rated wattage.
Why?
Sold more power supplies.
Power supply rated at 250 Watts?
Nope.
More like 60 to 70 percent of that.
Divide 250 by 10.
= 25.
Take that times 6. = 150 Watts (60 percent)
Times 7 = 175 Watts (70 percent)
Would like your opening statements clarified.
Post back in a Comment.
Regards,
joecoolvette
My ati radeon 5450 series card getting overheat
you could be pushing the video card to its max, and/or there might be something wrong with the heatsync fan
1helpful
Will an ati radeon 9250se graphic card be compatible in an emachine d2244 computer? there are two empty pci slots on the motherboard above the one that has the phone and modem conections. i have upgraded...
I am presuming you have XP on your computer.
According to ATI, this graphics board should work fine in a spare PCI slot.
Install in the top PCI slot as your CMOS detects top to bottom.
XP should detect the ATI board and will ask for drivers.
Install your CD drivers and or software as needed.
If you have VIsta or Windows 7, it does not appear ATI supports them for drivers.
Good Luck
http://support.amd.com/us/gpudownload/Pages/index.aspx
HP m7360n and ATI Radeon HD 5450 PCI-E 512MB DDR2, no display. Just bought a 400w Power Supply and 2GB Ram pc2 4200..no display when i start it up.
does the power supply you bought have a pci express power connector on it to allow the card to receive the correct voltage requirements, as that card is compatible with your system
3answers
My asus m2n32-sli motherboard won't start up; runs for 4 seconds then shuts off. currently hooked up to the mobo: have a 500W power supply; AMD 3300 64 processor; zalman cpu fan; 2 patriot 2GB DDR2...
The only thing i can suggest is remove one of your RAM sticks and see if the machine will boot. I had this problem with mine and it turned out that one of my RAM slots was faulty and would not boot if both RAM slots had RAM in them.
1helpful
My HP M7260n doesn't recognize my new Video Card...
You might need to uninstall the old video card device, so Windows does not use the old drivers for the new card.
Another option is to try and boot in Safe Mode (press F8 during startup), so Windows uses the VGA mode (which all video cards support), and then install the proper driver.
Installing the latest ATI driver updates might also not be a bad step.
What is the cost of Radeon HD 5450 1GB DDR2 PCIE HDMI and .......
Amazon show a XFX ATI Radeon HD5450 1 GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card HD545XZCH2
For $34
Amazon com XFX ATI Radeon HD5450 1 GB DDR3 VGA DVI HDMI Low Profile PCI...
eBay shows one USED for $19
XFX ATI Radeon HD 5450 HD 545X ZQH2 HD545XZQH2 778656056176 eBay
GOOD LUCK getting a seller to ship to India! Have a friend in the US buy one and let THEM ship to you!
Anthony
1helpful
ATi radeon HD4650 issue
First enable you onboard video the connect your monitor to it. Insert you ATi video card in the mother board. Boot up. Install the ATi driver. Shutdown. Trasfer the monito to ATi video card. Then enjoy with you new vedeo card!
cheers!
Grand Canyon Tech
Grand Canyon Tech
