Question about Noritz 13.2 Gallon Residential Tankless Water Heater - N-132M
How do your flush the heater out. I have a lot of sediment coming through my sinks in the house.
Question posed under tankless water heater.
1) Utube has videos. Search de-lime tankless water heater
2) Open following links for instruction pdfs:
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
http://waterheatertimer.org/pdf/Delime-tankless-water-heater.pdf
3) Open following link for tank-type water heater:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment for more free help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Sep 13, 2011
6ya staff
SOURCE:
Water Heater Rumbling When Running Cold Water In Faucet
Check and see if the cold water has been plumbed to the 'c' on the heater, the hot to the 'h', and the relief valve somewhere else, usually on the side. Maybe the plumber cheated somewhere to make installation easy.
Nov 29, 2013 | Rheem Water Heaters
When I run hot water for the tub, it has a brown tint
10 year old homes today usually do not have galvanized pipe. They have copper or pex plastic pipe. These do not rust.
Is rusty water on both hot and cold line, or just hot line?
Just hot line, then check anode rod and flush tank:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flush
Are you on water well? Well casing can get rusted. Water can have minerals. Call local water well service and describe problem in detail.
Are you on city water or mudd district water? Is pipe coming into house made of galvanized? Look inside meter box or look at pipe coming into house. Sometimes the city water line at end of run can get filled with sediments that will discolor water. Have water company flush the city water line.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 04, 2013 | Rheem Water Heaters
Rust in water heater tank
the tank needs flushed out ! heres how. Water heater manufacturers recommend flushing sediment from your storage type water heater periodically.
If your water heater is gas, set the gas valve to "Pilot" to prevent the burners from coming on while you are flushing it. If your heater is electric be sure to turn off the circuit breakers. With an electric water heater, if the water level drops below the heating elements and the thermostat turns the elements on, the heating elements will probably burn out quite rapidly. Connect a garden hose to the drain valve at the bottom of the tank, Close the shut off valve on the cold inlet to the water heater. open the temperature/pressure relief valve at the top of the tank by lifting the lever. Leave the valve open. Open the drain valve at the bottom of the heater allowing the water to flow out through the garden hose. when the water is clear your finished. close pressure relief valve on top of tank and turn water back on.
Open a hot water faucet in your house, and let it run until no air bubbles come out.
Turn the heater back on, and with gas units re-light the pilot light if necessary. good-day !
Apr 24, 2012 | Water Heaters
I own a house with an electric GE hot water heater. 8ESOT12AA01 Serial # 090122 5750 I do not know how old the hot water heater is and advice about when it should be replaced. No leaks to date but I...
GE is made by Rheem, but the market is always changing. Rheem-based serial number shows tank was made in 1990.
Tank will last as long as anode rod(s) protects steel tank from rusting.
If your tank has two anode rods, then tanks lasts longer.
That's how companies determine if water heater is '6-year' or '12-year.'
I don't have manual for your product to say if you have 12 year tank. Side of tank might have information blurb besides mandatory label that shows serial number.
You can update your water heater by replacing anode rod(s) assuming they can be loosened and removed after this number of years, which is a big IF with old heaters. Your plumber might have impact wrench he uses to see if anode can come out.
http://waterheatertimer.org/Leaking-water-heater.html
If the water heater is making gurgling rumbling and/or crackling sounds then tank has sediment build-up.
You can also get a baseline of rust by flushing tank and watching if water is very rusty.
http://waterheatertimer.org/Water-heater-will-not-drain.html
If you flush tank regularly, and inspect anode every 1-3 years, a tank will last many years longer than manufacturer's label.
http://waterheatertimer.org/Water-heater-manufacturers.html
Apr 20, 2011 | General Electric Water Heaters
We have a reliance 501 propane water heater model # 5 40 porto manufactured in 1991 We have had build up of rust in the pipes from the tank to our dishwasher and sink. Our dishwasher is not cleaning...
After 18 years there will be a build up . you could flush the tank and see what comes out, replace the line to the sink and dishwasher , then you can decide if you want to replace the tank .Which sounds like it will need to be done .
May 13, 2017 | Water Heaters
The water seems to be hotter than usual and my electric bill has increased by $100.00
There may be sediment buildup in the tank bottom, which can cause this. Shut off the electricity to the unit, drain off some water from a faucet that should be at the bottom outside of the tank and see what comes out, if a lot of dirty water and sediment comes out that may be it. Let it flush until clear water comes out. You will probably have to hook a garden hose on the faucet to get the water to a drain or outdoors.
Be sure to shut off the power to the heater first!
Then let the heater fill back up with water and turn on the power and wait for it heat up.
Jun 08, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Only hot water in sink/basin when toilet is flushed
I had a customer a few weeks ago that had the same problem. When the water heater was installed they crossed the supply lines. They had the inlet as the outlet. Esentially, the water heater was plumbed in backwards. Also there could be a miss piping somewhere in the house but it would probably be near impossible to find it right now without tearing up foundations. Also check that the faucet is not plumbed backwards as well. Especially if this is a single handle faucet that you are referring to.
Apr 06, 2009 | Rheem Tankless Hot Water Heater...
Sediment in hot water
With Rheem you have to back to the installer.Most of the heater have ten year warrany.
Mar 15, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
When hot water is on & toilet flushed the temp drops
Check strainers and screens into the sink, at the spout and into the hot water heater. Sediment buildup could be limiting the flow which woul make the system more susceptible to pressure drop when the toilet is flushed.
Jan 05, 2009 | Rheem Tankless Hot Water Heater...
Noritz 13.2 Gallon Residential Tankless Water Heater - N-132M Logo
121 people viewed this question
Top Noritz Water Heaters Experts
Fahr Quad
jasbo
jasbo
AndySmith70
Level 1 Expert
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
