SOURCE: d-link DWL-900AP+ Wireless access point CAN'T SET PASSWORD help!!
192.168.0.50 is the default address for your router, if router was boxed and new, this should be the router IP.
The router configuration must be done using a cable connection, cannot be done using wireless.
If you want to reset the router you can hold pressed the pinhole reset switch until the unit will restart, about ten seconds, this will reset IP to 192.168.0.50 . If router is irresponsive after reset and ethernet cable is tested and fine , then the router may be faulty.
You can call the phone number listed on the router manual to get online assistance.
If the router was not new, but had been re-programmed , the default IP may have been changed manually by the user, in this case do the following to find out the IP.
Click start button
Locate and use Run command
In the Run box type CMD, this will open command prompt.
in command prompt type: ipconfig /all
THe router Ip will be listed as 'Default Gateway'...192.168.......
You can also find IP by rightclicking on network connection, in Windows and choosing Status. ClThen clicking Support tab, and finding the default gateway IP address.
