Question about Maytag Ovens
F3 appears and it beeps when I try to preheat the oven
  • 2,341 Answers
The F3 error code means that the oven temp. sensor is shorted out....this tip i wrote explains in more detail what the F3 means and what to check. http://www.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
Posted on Sep 13, 2011
6ya staff
SOURCE:
Whirlpool gold oven message E1-F3-
whirlpool oven starts preheating then turns off and sends a message F-3
Nov 13, 2013 | Whirlpool Ovens
F3
F3
or
F4Shorted or open oven temperature sensor (RTD)Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Read more:http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Maytag Range / Stove / Oven Fault Codes#ixzz1kNxJMSok
Hope this helps you :)
Jan 24, 2012 | Maytag Ovens
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
My oven is showing f3 once its preheated and i set the timer it keeps beeping till i shut if off...what do i do??
That F-3 is a bad oven control or a bad sensor or both. 81aa179.jpgTo verify a bad sensor unplug the quick connect and check for continuity (bad if open)
Check for continuity between each wire and ground. If the sensor is grounded it is bad
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 22, 2010 | Ovens
Model GBS307PDQ5: Oven preheated to 425 degrees.
F3 usually means, that the oven temp. sensor is bad and one need to replace it.
The fact, that it's not heating tells me, the fuse in the back also needs to be replaced (requires pulling out).
Whirlpool oven repair orange county, ca
Feb 06, 2010 | Ovens
Service code F3 appears when turning oven on and trying to preheat.
Hello there:
The dreaded F3 code means that the oven temperature sensor is bad and that it will need to be replaced simply go to your local appliamnce dealer and give them your make and model number and they will be able to get this sensor for you
Hope this is very helpful for you
Best regards michael
Jan 13, 2010 | Amana AOCD2770 Electric Double Oven
Shuts off when preheating with F3 or F6 error
The F3 error on this model is an open thermostat circuit. The F6 is a control or loss of power. Make sure the unit is plugged into a good 120 Volt outlet. Test this outlet with a power drill or lamp, wiggle cord in receptacle, if no other test experience or equipment is avaliable. Check the thermostate in the oven for physical damage. There may be a loose connection in the oven. This would require a good technican to find.
InMrFixIt
Feb 20, 2009 | Kenmore 33169 Gas Single Oven
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
May 12, 2008 | Ovens
Kenmore Electric Oven Model 4088816 - Error Code F3
f-3 means the oven temp sensor is bad. replace the sensor and problem solved
Nov 25, 2007 | Ovens
Ovens Logo
445 people viewed this question
Top Maytag Ovens Experts
Marvin
Marvin
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
