RCA DRC6309 9 in. Portable DVD Player with Screen Logo
Posted on Sep 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My rca DVD -DRC 6309 works fine independently. However, when I connect it to other video items ( TVs) I only receive Audio. Not video. Regardless of what source I use on the TV. I've checked the cable, I've checked the TV. Both are doing fine with other video sources. Am I missing something. I don't have a manual, but it's a very basic connection.
richie46
Level 3:
Top Expert:
  • RCA Master 12,962 Answers
  • Posted on Sep 14, 2017
richie46
RCA Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2942931
Points
58151
Sounds like a hookup situation. Why not go to web site and download manual for the correct procedure and wires to be used for various situations.
1 Related Answer
Anonymous
  • Posted on Jan 25, 2009
SOURCE: RCA F32648 32" TV DVD Connection
My daughter is having the same problem with the same model tv.. I had a bit of trouble finding the manual for that tv at the RCA web-site --- but I did find it at Amazon.
The URL for the pdf version of the manual is:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000032746.pdf
Assuming you have the remote for the tv, there are instructions in the manual for setting up the relationship between the DVD player and the TV.
(The URL for the TV on Amazon is: http://www.amazon.com/RCA-F32648-32-TV/dp/B000050FZR The link to the manual is toward the bottom, in the Product Details section.)
No right channel on AV2
First, does TV sound without external sources work on both channels?
With the one RCA connected and getting sound, unplug it and plug into other channel. Any sound? If not, remove it and plug the other RCA by itself into the left channel. Sound? If yes, plug it into the right channel. No sound? If not, bad TV input.
If you do get sound on that other channel with a single RCA, then you have either a bad cable or bad source. Reverse RCA's on source and try same test, plugging each RCA into each input on TV one at a time.
If the TV is bad, you will get sound on just the left channel regardless of which RCA you use.
1helpful
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
I connected my receiver to my hdmi dvd player and ps3. I am able to get a video connection however there is no audio. I have connected evrything via HDMI. Also, I ran all the troubleshoots mentioned in the...
You are not alone...Sometimes HDMI connections fail to provide Audio on some equipment ...
You should carry Audio separately with a RCA cable..
OR without HDMI ,you can make the following connections:
** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your DVD
** to "AUX input " or "DVD " OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
RECEIVER corresponding your RCA or Optic connection...
There you go..Both DVD sound and Video are on the
Receiver..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
We recently purchased an AVR 146 receiver and have attempted to connect our DVR satellite receiver, a DVD player/recorder and our Hitachi (non HD) TV, plus a surround sound system to it. The surround sound...
This is how the connection is suppose to be, DVR "OUT", to TV "IN" using the RCA plugs, then press AV on the TV. If this is how you connected it, then maybe there is something wrong with the video wire (Yellow).
As for the DVD, you need to connect an Audio wire separately because the component Red + Green + Blue wire only stands for video. Audio is Red and White, this must be connected for you to get sound from the DVD.
To connect the Audio for your DVD player, connect Red and White wire to Audio "OUT" of your DVD player, to "AUX" in of your AVR 146 receiver, then select AUX on your receiver and sound will come out from your DVD through the receiver.
I hope this is not complicated for you. This connection is simple, all you need is to understand the basics which is OUT and IN. If you want to watch DVD on your TV, this means the DVD will be good OUT to IN of the DVD. The same goes for audio.
If you don't understand, please let me know so that I can direct you further.
Good luck.
2answers
We have a cable box, rca reciever, a dvd and a non digital tv. Does the reciever need input from cable box, dvd and tv?? is red, yellow and white audio/video enough to connect or is a S-cable or optical...
From your cable box, send "optical" to the receiver. From the DVD send "coaxial digital" (looks like one rca cable" if your receiver has it, if not, optical is fine as well. There is no reason to send audio from the TV to the receiver unless you are using an "off-air antenna". If you want to have audio from the cable box to the TV for listening to TV speakers only, send an audio video cable (red/white/yellow) direct to TV. If you need more help just post a comment and I can help you some more.
1helpful
2answers
No sound unless VIDEO signal is plugged into receiver
Connect the DVD player audio with digital coax into the digital audio connection as you described and the DVD video directly to the TV. Now switch the input mode on the receiver to DVD. Then switch the video output mode on the TV to correspond to the input you plugged into. Any source in 5.1 dolby digital or dts should now work properly and have picture too.
4helpful
Need user manual for RCA DRC 8310
JHudJr. The manual you're looking for can be downloaded using the address provided below. [email protected]
RCA DRC8310 User Manual (PDF 3.25mb) <---click to begin immediate download
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
2answers
Hooking up the RT 2600
connect all the devices into the receiver inputs then there should be 1 set of outputs to the tv. This is to play everything using surround sound as all the video and audio is going through your recevier... if you want to do HD and have surround sound you will need a new receiver as this one has no hdmi inputs or outputs.
2answers
Jvc stereo receiver rx-5032vsl
If your TV is a higher quality set that is HD capable, the problem may be in using RCA jacks. I suggest buying some component video cables. Some higher quality DVD players and TVs do not respond well to cheaper video feed wires. The only other option is a problem with the DVD player since the picture is coming through fine through other DVD sets. Try the wires first, its your cheapest option.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
