SOURCE: F9-6 fault code on maytag gemini double oven range
I waited until the next morning and hit the cancel button. It cleared the error
SOURCE: The Maytag Gemini is didplaying an f9-3 code, what
somthing wrong with upper door lock, bent, door misaligned, problem with lock itself
SOURCE: Getting Error Code f9-5 and f9-6 on MER6770
This is a bad electronic clock assembly and it is very simple to repair. You can save a lot of money by making this repair yourself, too!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 7 PM CST and we will get the correct part, as well part removal/installation instructions to you .
We look forward to working with you. Thanks, Ella
SOURCE: Maytag Gemini double oven flashes F1 and stops heating.
I am attaching a Gemini manual. The checking procedures are the same for your oven.
Two component suspects for your problem would be the door latch mechanisms and the oven temperature sensors.
http://www.servicematters.com/maytag_library/docs/16010161.pdf
SOURCE: Maytag Gemini bottom oven not working
both ovens on my new stainless steel maytagmgr6775 not heating up.............
F9-2 error code indicates:
