Samsung LN32C530 32 in. TV Logo
Posted on Sep 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
14 month old samsung 32in 530 series lcd tv will turn on fine, then after a few minutes start turning on and off repeatedly for ever...until i pull the power. What do i do, call samsung?
Chi Chu
Level 3:
  • Samsung Master 8,457 Answers
  • Posted on Sep 12, 2011
Chi Chu
Samsung Master
Level 3:
Answers
8457
Questions
0
Helped
2822913
Points
26282
Call Samsung Corporation,if u want to.Samsung might,might not help u.They only warrenty tv parts and labors are only 1 year though.The tv problems u discribing are 90-95% it is the tv power supply board problems and it is the causes.That the tv board that where the tv power a/c cord plug into it.If the Samsung Corporation will help u that great.If not.U must take the tv aparts and must check the tv power supply board carefully for to be sure that the tv causes and problems.100% for sure,it is the tv power supply board it is the problems and the causes,if ur tv power supply board have dying and leaking capacitors components parts.These capacitors components parts are the causes and problems and not helping tv to power up any more,if capacitors components parts are bulging up or puffing up onto it tops.If u have all the tools and known basic electronic?Yes? The tv power supply board must have be change all these leaking and dying capacitors components?Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Anonymous
Level 2:
  • Expert 85 Answers
Anonymous
Expert
Level 2:
Answers
85
Questions
Helped
23215
Points
216
Its possibly dry joints on the power supply-the heat generated causes the solder to crack,and when warm creates a "crater" on the affected joint and expands with heat,and loses contact until cool.(retraction).should be easy if you are handy with a soldering iron!.failing that,take it to a repair shop as its out of warranty,and samsung will not want to know! (unless you got extended warranty,of course!)
good luck,steve
2answers
I have a 15 month old Samsung 65" TV UN65TU8000FXZA that stopped turning on and off.
It cold be the power supply is going bad for your TV and that the TV is starting to die on you guys and it would be more cheaper to buy a new TV than to try and repair the old TV that is no longer working anymore.
KF50XBR800 Rear projection LCD TV on and then standby
from how long you have this problem? and what made it start?
do u remember the cause?
Samsung LE22B450C8W LCD TV freezing picture/sound
The Main bd needs a Firmware update or it is going bad.
Call Samsung and have them look up your warranty by the Serial number. Keep calling to get a different agent until they agree you have a in warranty set and agree to repair it.
Toshiba lcd series 6, 18 month old tv will not
consult manual for troubleshooting it could be that lamp in tv takes long time to cool down or that it is bad they usually last about 2-3 years depends on how you use your tv
Frozen samsung TV - wont turn off
since you say you have had it just a short time
call samsung and request service for your set this is a problem and will get worse
if its just a couple months old parts are still in warranty and not sure of labor there is a warranty statment in the owners manuel
Samsung series 5 530 46" LCD
RE: Product Defect
If Its new enough to return without store rejection or if you still have a valid warranty --take it back! --
Samsung HPS 5073
Unplug TV, take off the back. One each board there will be capacitors. the tops are flat unless one has blown then it is bubbled up. If you find one that is bad, copy the number and search the internet for a replacement. Unsolder and remove the old one ( there is a line drawn on the negative leg, mark the neg side on the motherboard so you can replace the new one the same way). Now solder the new one back onto the board. This worked for my TV, hope it helps
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
