My lcd monitor syncmaster 920nw won't turn on. Even if i press the button on the lower right side of the monitor, it (usually blue light) doesn't light up.
If the power indicator remains on, the problem lies in the inverter board that powers the back lights. The cause is usually bad capacitors that sometimes bulge showing they are open. the board needs to be replaced or an attempt made to repair the old one.
Yes, More than likely the problem with the unit is blown capacitors on the power supply board, the flashing power light is a good indicator of this type of failure. Here is a link to a repair guide with pictures and videos showing how to open the unit and what to look for and replace to get it back going again.
The clicking sound you hear is the power supply board trying to start up, this indicates the board has failed. This is a common problem with all LCD monitors after a few years of use. Parts called capacitors on the power supply board fail and they will keep the power supply from starting up correctly. If you can solder then you can repair the board yourself. Here is a link to a repair guide with pictures and videos showing how to dis-assemble the unit and then what to look for and replace to rebuild the board and get the unit back running.
The 920nw did have a 3 year warranty on the unit but they will be out of warranty now. The flickering power light is an indication of a failure in the power supply board. When the board fails it can't start up correctly and the power shuts down over and over so you get the blinking light and no display. This is a very common failure point on all LCD monitors after a few years of use. There are parts called capacitors on the power supply board and they filter the output power. When they fail the power is not properly regulated and the power supply shuts down and tried to restart so you get the flashing. Here is a link to a repair guide that will show you how to dis-assemble the unit and then what to look for and replace to get it back up and running again.
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
