Five blinks - AKB
circuit (automatic kine bias), the timer/standby indicator blinks
for about 30 seconds then goes to the self-diagnosis function.
Something is wrong with the video. Check video out, Q705, 732, 761
and other components on the C board, also check Q218, 219, 220 on
the A board. In addition, unit could be in IK blanking, try turning
up screen A2 slightly.
What I realised is that the coil temp sensor is located at the buttom of the evap coil. At that position it does sense the change it temp. I had checked another carrier (not the same model) and the coil sensor was located higher up. So I removed it and tied it up higher up on the coil. This is after I had swapped cicuit board, and all sensors. The higher up position allows it to sense a change in temp on the coil.
