Question about Craftsman Convertible 25cc. Gas Line Trimmer
How do you change a craftsman 32cc weedwacker gas filter in the gas tank?
  • Craftsman Master
  • 7,482 Answers
Hi davemac918...
I used a long pair of tweesers to grab the filter, but you can also grab it with a piece of wire with a hook bent on the end of it large enough to fit the tubing the filter is inserted into.
Hook the filter tubing, and pull the filter to the top of the tank and manuver it out of the tank.
Please take time to rate me
Posted on Sep 11, 2011
    New Friend:
  • 3 Answers
You can buy the whole kit at home depot
Posted on Feb 09, 2013
  • 66 Answers
Http://www.searspartsdirect.com/partsdirect/Grass-line-trimmer-help/Replace-the-Fuel-Line-on-Your-Grass-Line-Trimmer
I’m happy to help further over the phone at https://www.6ya.com/expert/william_83fc156eee2b555e
Posted on Aug 04, 2012
    President:
  • Craftsman Master
  • 1,545 Answers
You would be well advised at that point to change the filter, fuel lines and primer bulb. It will save lots of headache in the future.
http://www.ereplacementparts.com/articles-c-8873.html
2 Suggested Answers
6ya staff
SOURCE:
digritz
david mcclellan
  • 530 Answers
SOURCE: craftsman 32cc would not idle
If you are certain that you have correcting gaped the plug then the next step is to readjust the low end idle carburetor. If you look you should see two holes in the plastic cover that lead to the flow adjustment screws they may even be out in the open. If they are not labeled H and L (the L is the one you want), check your manual for the correct one. A good place to start is turning the screw all the way in then backing it out 1 1\2 turns. Then check it. If you still have problems do 1\4 turns out. After about one full turn from that you might want to consider taking the carburetor off and removing the float bowl or the bottom for a good cleaning. A sticking float could cause problems with your fuel flow.
Hope this helps.
Posted on Sep 03, 2009
Craftsman 25 cc Weedwacker
Look for air leaks in the gas line and around the carb , a bad gas cap will not let any pressure build up. It could be that too. Check also the fuel line and filter inside the tank. replace if needed.
www.ereplacementparts.com has parts for craftsman or the online Sears Stores.
Nov 01, 2017 | Craftsman Garden
My 32cc 4 cycle craftsman weedwacker won't run off choke
MORE THAN LIKELY YOU HAVE BEEN USEING ETHANOL FUEL NEED A METANOLE FUELCLEANER AT MOST AUTO PARTS SUPLYER THEY SELL A FUEL CLEANER FOR SMALL ENG. IF NOT THAT MAKE SURE FUEL LINE IS NOT CRACKED
Nov 15, 2011 | Garden
Was given a craftsman 32cc weedwacker. no manual. need to know what fuel it takes.
The website just says gas/oil (http://community.craftsman.com/Craftsman-Convertible-32cc-Gas-Line-Trimmer-reviews?tab=details). I'm not sure what that means. But on the Craftsman Community web page (http://community.craftsman.com/community) there is a link that says Feedback and Support. If you click that and fill out the form, someone should get back to you.
Hope this helps!
Jun 17, 2011 | Computers & Internet
Need to know the 2 cycle oil to gas ratio for a craftsman 32cc weedwacker trimmer
My Craftsman 31cc 2-Cycle Gas WeedWacker Model C216.51318 manual calls for a Fuel Mix (gas:oil) of 32:1
Jul 11, 2010 | Garden
Craftsman 32cc would not idle
Hope this helps.
Sep 03, 2009 | Craftsman Convertible 25cc. Gas Line...
Have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
May 04, 2009 | Craftsman Garden
Craftsman weedwacker keeps dying
If the weedwacker runs OK on 1/2 choke or even better on full choke then most likely the cause is the carb gaskets are stiff and can no longer pump the fuel. Of course make sure the fuel lines are are the right ports (return and supply). While you have the carb apart clean all of the passages with carb cleaner.
Apr 16, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman Convertible 25cc. Gas Line Trimmer Logo
1,540 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
