SOURCE: Ice maker not dispensing ice
It is possible that the water valve behind the refrigerator is either defective or the wire connection is loose. Also check the fill tube where the water comes in and see if there is ice blocking the fill tube. Since it's under warranty, have it serviced by the LG warranty to resolve this issue.
SOURCE: ice maker
SOURCE: Kenmore elite (106.53606202) ice maker will not dispense ice
The power was off at my huose for 12 hours. When I removed the ice bucket I saw that water condensated and was now frozen around the shaft of the ice dispenser moter. The ice was prevent edthe motor shaft from turning.. I used a pair of needle nose pliers to loosen the 2 mouting bolts of the ice dispense motor approx 1/4 turn and all is well.
My wife thinks it's a miracle and that's all that matters!!!
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
SOURCE: Ice maker quit making ice...
Hello, Check the water fill tube to see if it may be frozen. It's a tube about 3/8" wide that hangs over the tray. Squeeze the tube and if it is hard, it"s frozen, if it is soft, you have another problem. If it's hard, take a hair dryer and thaw out the tube and you ice maker should be fixed.
I hope this helps.
CYA, Gator241
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
