Amazon Kindle 1 Logo
Posted on Sep 11, 2011
How do i charge my kindle comes on screen battery flat
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Oct 29, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1077
Points
6
You kindle should have come with a usb cable (one end is different from the normal usb on things like pen drives) and also a little plug with a usb port on it. If you plug these two together, then plug the other end of the cable into the kindle, once you plug the actual plug into the wall, your kindle should start to charge (you can see this by a light appearing on the bottom of the device). You can also plug this cable straight from your kindle to the computer. This will also charge it (though slower than through the mains).
2answers
How to Fix Kindle Paperwhite Frozen on Lock Screen?
Oops, are you troubleshooting the Kindle Paperwhite Screen Frozen problem? Have you tried all the possible ways to solve this difficulty? Not to worry, if the steps you perform don't work, we are here with some fully searched solutions that will help you to overcome Kindle Paperwhite Frozen on Lock Screen. Follow the guidelines step by step to get out of Kindle Paperwhite Screen Frozen matter easily on your own.
Steps To Solve Kindle Paperwhite Screen Frozen In Minutes
Charge The Kindle
A very common reason that leads to Kindle Paperwhite Screen frozen is the lower battery. It can be possible that you are facing screen stuck issues as of the empty or uncharged battery.
So, to let your device work properly you have to charge it first. Hopefully, charging your device will help you to overcome Screen frozen on Kindle.
Uninstall Corrupted File
If you have downloaded a wrong or corrupted file then you are definitely going through with Kindle paperwhite frozen on lock screen as well as scattering issues with Kindle.
Kindly uninstall the corrupted file as quickly as you can do, otherwise, it will cause damage to your device.
2answers
My Kindle Fire will not charge
need to test charger --port and battery
My Kindle will not charge - I have trued with various chargers I own
Hello
Just follow these steps to fix this issue:
1. Plug the device into the Kindle A/C adapter (not your computer) and let it charge for a few hours. Be sure the charging light is lit -- sometimes a drained Kindle will stop charging a few seconds after you plug it in. Unplug and replug until the light stays on steadily, then leave it alone. Most of the time you'll come back to a restored kindle. If not, go on to step 2.
2. If you still see the same Critical Battery screen after charging, unplug the USB cord, then hold the power slide to the right for at least 20 seconds.
3. Release the power slide, then immediately press and hold the Home key for another 30 - 45 seconds.
4. Once the Kindle's screen begins to flash, release the Home key. The eReader will boot to recovery mode. To continue, press and hold the R key until the screen flashes again.
5. After the device is finished rebooting, you may see the Critical Battery screen once more. If so, plug in the USB cord and wait for the Kindle to return to the Home screen.
For any help or query visit us: www Kindle Com Support
Screen does not show a status bar any longer. how to I recover it?
Amazon.com Kindle Help Forum
www.amazon.com/gp/help/.../kindleqna?ie...
Amazon.com, Inc.If you have a newer Fire you swipe down from the top of the home screen to open it. ...I can't get the settings bar to show up, because swiping doesn't work. .... Does anyone out there have any ideas on this problem? .... have erased ALL of them) still no status bars/times/access to anything. oh and mine is the kindle fire hd.
About Charging Your Kindle Fire - Amazon.com
www.amazon.com/gp/help/.../display.html?ie=UTF8...
Amazon.com, Inc.Kindle Fire 2nd Generation: Fully charges in 3.3 hours; Kindle Fire HD 7": Fully ... The battery indicator at the top of your screen should also have a lightning ... You can showthe percentage of the battery charge in the Status Bar at the ... Your Kindle Fire will not charge as efficiently when connected to a computer and in use.
Navigating Your Kindle Fire HD 8.9 - Amazon.com
My Kindle won't charge
If the battery isn't too far gone, here's how to revive it: Plug the device into the Kindle A/C adapter (not your computer) and let it charge for a few hours. Be sure the charging light is lit -- sometimes a drained Kindle will stop charging a few seconds after you plug it in. Unplug and replug until the light stays on steadily, then leave it alone. Most of the time you'll come back to a restored Kindle. If not, go on to step 2. If you still see the same Critical Battery screen after charging, unplug the USB cord, then hold the power slide to the right for at least 20 seconds. Release the power slide, then immediately press and hold the Home key for another 30 - 45 seconds. Once the Kindle's screen begins to flash, release the Home key. The eReader will boot to recovery mode. To continue, press and hold the R key until the screen flashes again. After the device is finished rebooting, you may see the Critical Battery screen once more. If so, plug in the USB cord and wait for the Kindle to return to the Home screen. - See more at: http://www.laptopmag.com/articles/kindle-critical-battery-error#sthash.Rtxwp4El.dpuf
How To Restore Your Kindle If It Experiences Critical Battery Error
f you can't get past step 3, the battery might be too far gone. Contact Kindle customer service via phone (866-321-8851) to walk through extra troubleshooting steps. If they can't revive it, Amazon will usually replace the eReader for free. - See more at: http://www.laptopmag.com/articles/kindle-critical-battery-error#sthash.Rtxwp4El.dpuf
3answers
2helpful
4answers
The kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
How do i know my kindle is fully charged
It is supposed to turn green when fully charged. There is also a battery charge indicator on screen.
http://www.amazon.com/gp/help/customer/display.html?nodeId=200728630#battery
2answers
My kindle light won't turn on to awake and when I tried to plug in to charge,no light came on.
If the charge light won't even come on then it sounds like you have a dead battery in your kindle and need to replace it.
Call support and order a new battery.
http://www.amazon.com/gp/help/customer/display.html?ie=UTF8&nodeId=200212360
2answers
My kindle cannot power on
  • Make sure the Kindle's battery is charged. Connect to a PC using the supplied USB cable until the power LED changes colour from amber to green.
  • Slide and hold the power button until after the power LED blinks three times. If the screen now is blank, repeat the procedure
If the Kindle still does not come back to life, contact Kindle Support.
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
