Hi First
make sure that nothing is blocking the drain pump assembly located inside the
bottom of the unit, after this test the door lock-switch assembly. If the door
lock-switch is also fine then the control board should be replaced. Hope this
helps...please post back for further assistance. Daniel
Hi jaejin_a_jun,
There are 3 likely causes.
1) Is the door firmly closed, it could be the door lock is not activated properly - Please check.
2) Is the Water open at the tap - Please open it fully
3) Is the Inlet hose or Outlet hose kinked? - Please straighten it
If these check out well, it could mean a possible component failure.
To check the drain pump (attached to drain hose at bottom) and Inlet hose (attached to inlet hose at top inner cavity) attached direct power to the 2 points found on each.
To chek door lock, check for power from the PCB to it via a Multimeter.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Hmmm I checked the door, hose and water. They're all set correctly..., so it must be component failure??..
I tried to contact a couple of repair persons but both didn't want to take a look or fix eletrolux washing machine.
Do you know where I might be able to get a repair person for that?
Thanks for your advise.
