Konica Minolta DiMAGE A1 Digital Camera Logo
Posted on Sep 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CCD failure - Konica Minolta DiMAGE A1 Digital Camera
Anonymous
Level 3:
Brigadier General:
  • Master 3,006 Answers
  • Posted on Sep 10, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
3006
Questions
0
Helped
960063
Points
10121
Sell your camera for spare parts, the fault requires a professional repair costing far more than the camera is worth. Note that you'll get more by selling the battery, body caps (hotshoe cover, sync socket cover, lenscap) and camera body as separate items.
Konica minolta bizhub c451 machine status s1
CCD gain adjustment failure. The CCD is located under the main glass. There is a white strip located on the underside of the glass that the CCD gets its calibration reading from, this strip may be dirty. After cleaning the strip reboot the machine. If error returns the CCD may need to be replaced.
1helpful
Only settings display on lcd no image
This will either be the setting on the DISP button (back of camera) or a failure of the CCD (image processor). If the pressing of the DISP button does not restore the picture then it will be a CCD failure. The CCD failure was a common fault with the Canon A cameras and Canon repaired these free of charge up until a couple of years ago. This can be replaced by a Canon repair centre, however it will be costly. Hope this helps.
1helpful
I'm getting an E7-10 error message on my copier
10 Content CCD black level error
Details CCD black reference plate scan level
abnormality when the copy lamp turns off.
Cause Flat cable installation failure to CCD unit.
CCD unit error.
Check
and
remedy
Check flat cable installation to the CCD
unit.
Check CCD unit.
Is your lamp coming on? If so most likely the CCD assembly needs replaced, That would require replacing the carriage that contains the lamp and mirrors, the CCD is mounted to that and is laser adjusted at the factory.
1helpful
Dark screen
have you prove to pic fotos. if the camera make fotos,and memorize on the card, but you cant see the foto in the camera schreen this is only a lcd defekt, you must prove if the lcd flat is right connected. if the camera dont pics foto, the problem is in the ccd. you must change the ccd. allor. memorize fotos and you can see trhe foto on your pc...lcd problem contact failure ore lcd faul to change. if the camera dont pics foto...ccd failure to change the ccd.
3helpful
Lines and distortion across screen when on. If picture is taken it shows those lines and distortion
It is known problem of ccd imager chip failure in Canon A60 camera and ccd imager chip will be replaced to fix this issue.
Canon offers ccd imager chip replacement free of cost, click Canon CCD Imager Advisory for details.
Thanks.
3helpful
Everything looks distorted and has vertical streaks
It is known problem of ccd imager chip failure in DSC-t1 camera and ccd imager chip will be replaced.
Sony offers free of cost ccd imager chip replacement for DSC-T1 camera, click Sony CCD Imager Support for details.
Thanks.
Technical problems with dsc - t1 digital camera
This is known problem of ccd imager chip failure in DSC-T1 camera and ccd imager chip will be replaced to get live view in LCD to take pictures.
Sony offers free of cost repair for DSC-T1 for ccd imager failure problem.
Click Sony CCD Imager Support for details.
Hope this info will help you to get it fixed.
Thanks.
1helpful
Pictures are all black
If camera shows previously taken pictures in playback mode and does not show live view to take fresh pictures then it is ccd imager chip failure. CCD imager will be replaced in your Canon A75 camera.
Canon offers free of cost ccd imager replacement, click Canon CCD Imager Advisory for details.
1helpful
The display screen is blocked. The lens is open. Can see outline of blockage
If Canon A70 camera shows previously taken/ stored pictures properly in playback mode and does not show live view in LCD in camera mode to take fresh pictures then it is ccd imager chip failure problem and ccd imager chip will be replaced.
Canon offers free of cost repair for A70 for ccd imager failure problem. Click Canon CCD Imager Advisory for details.
2helpful
2answers
My canon powershot A75 stopped displaying pictures (or taking them, it seems).  The flash goes off, the shutter is open, and the display shows.  Just no picture and no display.  Do I just buy a new one?
Its is failure of CCD Imager and CCD Imager part will be replaced in your Canon A75
Canon will repair it free of cost as per announced scheme for CCD Imager failure.
You can have details on Canon CCD Imager Advisory, how to get free repair facility.
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
