If Your TV and Laptop have HDMI Port then you just need a HDMI Cable.
But if you dont have HDMI port. then you need two cables one from video and one for audio.
For Video you either VGA Cable(if you have VGA Port in your TV) or VGA to RCA Cable (Yellow Pin will be for video)
For audio You Need 3.5mm pin to RCA (white and Red for audio).
This pic is of VGA to RCA Cable
Your TV should have a VGA PC in-port somewhere in the back. Look for a blue connection with three rows of pin-like holes on the back of the TV. There should be the exact same connector on the left side of your laptop. This is a standard cable used to connect to LCD computer monitors as well. I hope this helps.
