Turn off the gas,unplug the power. Take the cooktop out of the cutout and support it on the countertop. Remove all grates and valve knobs. Remove all screws from the valves and the burners. Remove the burner base plates. You may have screw on the side holding the top to the base,if so,remove these too. The top will separate from the bottom exposing your parts.
Hardware store or appliance store that has a parts department.
You have a gas stove? Lift the grate, drop it in. Electric stove? Pull the burner up and away from the plug (look down at the burner, there are two pieces that go probably toward the center of the stove). Same as gas, drop the tray and reinsert the prongs into the plug.
Contact this gentleman: Sandor Horky [email protected] He helped us with parts we needed for our CREDA Model GGH110. I believe the company ADCO is the after market people for CREDA. Good Luck. PA Fi.
sound like you are on the right track if you have found the screws under the burner caps. some of those types has a big brass nut. some of them you have to remove the unit and access from underneath. send picture of what you are looking at if you like. good luck
