SOURCE: Seiko Sportura SNJ007 chrograph watch instructions
good evening ! use the shortes button of your seiko sportura to set the analogue time press it slowly until you search a correct time ! thanks ! good luck !
SOURCE: re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. [email protected]
SOURCE: can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
SOURCE: I cant adjust the minite hand backwards if the watch is gaining
Unfortunately your watch do not have reverse action, so, you have to go all the way forwards till you reach designated time again.
One more way how to set the right time is to disconnect the battery and wait till the real time reaches the hands of your watch, then put battery back and set again. If watch has a STOP function (crown pulled out), then you don't have to disconnect the battery- just pull out crown and wait.
By the way: pushing the button in accelerates minute hand constantly, but if you'll push the button rapidly, it will move mimnute hand bit by bit. Use this feature to set desired time more precisely.
Do not forget to rate, please.
