You did not help me and I put the request in 2 times and you are double billing me. You said if you do help there is no charge. Please credit my account. I am calling my credit company to deny the charges.
Thanks,
Robert E PanoshYou did not help me and I put the request in 2 times and you are double billing me. You said if you do help there is no charge. Please credit my account. I am calling my credit company to deny the charges.
Thanks,
Robert E Panosh
You can't post conmments that contain an email address.
Microwaves do normally 'turn on', in that the light comes on and the fan starts running. If the turntable starts turning and it is emitting microwave energy, then you need to take it for service or replace it. To me, it sounds fine.
hi,
there is a micro switch that signals when the door is closed. this tells the machine that it's okay to start the turntable and heating process.. if the micro switch breaks or shorts out then the switch does not send the signal so the machine does not work.
hank
The turntable is a seperate intenty from the microwave itself, I would presume that the switch that turns off the turntable when the door is opened needs replacement.
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on.
The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent.
Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second.
That's perfectly normal.
The relay on the control board must also be turned on before it will actually be cooking.
Thanks,
Robert E Panosh
