I have been using my printmaster gold 18 with windows 7 although I just realized I cannot save a project as a pdf file. is incompatibility the reason for this?
Installing PrintMaster 18 on any computer requires .NET Framework 1.1 to be installed on the hard drive. If NET Framework 1.1 is not installed, it will be installed from thePrintMaster 18 install disk before PrintMaster 18 is installed.
If possible download .NET framework 1.1
If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant" in Windows 7 will display this message.To continue with the installation, select "Run Program".
I understand that you are inquiring if Printmaster 18 is compatible with Windows 7. Our developers have tested every aspect of Printmaster 18 to see if it will function properly on Windows 7. It has passed all tests except one, which is the Save As PDF feature. Our developers just became aware of this and are working on a resolution to make it work on the Windows 7 operating system. We apologize for any inconvenience this has caused, but we can assure you that we will provide a fix for this as soon as possible.
Here's my solution: Don't waste your time and money on, use a program other than PrintMaster! PDF is universally accepted across formats/browsers/OS ...what kind of program would not export THE most commonly used format????
printmaster 1 was for windows 98, ver 17 is for XP. it depends where your saved projects are. if they are on CD media then that is READ ONLY and they must first be transferred to a C:\ drive and their ATTRIBUTES for each and every file/folder of the project need to have the Read Only attribute removed. you can do that via CMD.exe eg if your project was inside a folder called c:\myprojects\????? then you would type in ATTRIB/S c:\myprojects\*.* -R then your projects might be valid as they could be UPDATED/Altered by the new version but thats just a guess.
As a work around untill we can figure this issue out. http://www.acrosoftware.com/Products/CutePDF/writer.asp This is a FREE PDF Print to file program.
At the top left of the page the are links to the PDF Creator and the Required GPL Ghostscript 8. The program will not function without it. Both programs work with x64 Vista. Read the website for the other benifits or the program.
found the fix for printmaster 18 broderbund pdf saving problems...
1-close all open programs and return to desktop.
2-click START and choose CONTROL PANEL
3-click PRINTER
4-right click on BRODERBUND PDF CREATER, then select PROPERTIES (the broderbund PDF creater properties window will open)
5-click the PORTS tab, then select ADD PORT button. (the printer ports window will open)
6-click NEW PORT, then enter PMPDF in the ENTER A PORT NAME window, then click OK
7-click CLOSE at the PRINTER PORTS window. you will now be looking at the broderbund PDF creater properties window
8-a check mark will be located next to the new PMPDF printer port. click APPLY. the broderbund pdf creator will now be located next to the new port. click OK.
9-exit all windows and restart the computer. once the computer restarts, you can save your project as a pdf file.
1.In Tools/Options/General Options, check the box beside "Optimal Printing Resolution". 2.Go to File/Printer Setup/Printer Setup. 3.Under "Name" select Broderbund PDF Converter v2.10d 4.Next, go to File/Professional Printing. 5.Select "Save As PDF". 6.At the next screen, type the name of the PDF file you want to save in "Project Name". 7.Under "PDF Resolution", select 600 dpi. 8.Click on "Save As". In the next window, browse to the folder in which you want to save the file (for example: My Documents). 9.Click on the "Save" button. 10.PrintMaster will save the PDF file to the folder you selected. 11.Open the file in Adobe Acrobat to make sure all the elements and pages are there and that it looks as expected.
