For Sony vpl ex1Go to MENU, INSTALL, and then use FLIP to reset the projected image to match with your installation. Other projectors will have a similar installation page using the menu option For Sony vpl ex1Go to MENU, INSTALL, and then use FLIP to reset the projected image to match with your installation. Other projectors will have a similar installation page using the menu option
You can't post conmments that contain an email address.
You turn the unit upside down.
http://support.dell.com/support/edocs/acc/2300MP/en/usage.htm
Go to the menu.
Go to management.
Go to Projection Mode.
Front Projection-Desktop: If you want it to project right side up off a table. Front Projection-Ceiling Mount: If you're hanging it off a ceiling.
Press MENU on the remote control (as show on picture below)
the menu window displayed
Press down arrow key to select ADVANCED
press ENTER on the remote control
use down arrow key to select ceiling (as show in picture)
press RIGHT arrow key to select OFF to ON status
press MENU key to exit menu
(the projected images are horizontally and vertically reversed.)
Since you have not mentioned the model it is diffficult if the option of reverse image is available on the menu. If so all you need to do is to scroll the menu and reverse/invert this image. If not the other option is to mount the projector with the projector fitted on a small stand in the same direction and not invereted. I hope you will search for this in the menu or in the rear panel. If not mount it in the actual position with a stand so that you can corrrect the height using the provided screw adjusters.Helpful? Good day
This is the Manual
http://www.projectorcentral.com/pdf/projector_manual_2869.pdf
Your projector is setup for use on the ceiling, and must be reversed.
Please "set the "Projection" command in the "Extended" to match the installation method.
Consult the manual for further assistance.
go to menu and press it---press right or left arrow button and go to installation press enter. --go down by down arrow to image reverse- use left and right arrow to adjust the image to the correct position.
