The green and red are alligned and fine. but the blue is like a glow on anything white. when alighing green and red its straight lines when to the blue its like spread out. what and how do i repkace ot fix this
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture. If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Most cheap jacks have 4 wires, red, green, yellow & black. Most modern houses have wires paired up (twisted pair) like blue & white with blue line or stripe. Line 1 is red/green or blue/white. Line 2 is yellow/black or orange/white(with orange line/stripe).
Hi, There should be a convergence adjustment on this set. It will have a "cross hair" type pattern You adjust the beams so that the cross hairs turn white. I believe Green is not adjustable intentionally. The procedure is to adjust the vertical Red line until it alligns with the Green line. Then adjust the vertical Blue line until it lines up with the Red and Green. The line should turn White. Repeat the procedure for the horizontal lines. When you return to regular viewing mode the double images should be greatly reduced or eliminated.. Hope I've helped you, Best Regards, Mark
is this a panasonic it is normal that the blue be more intense than red and green if the line in the middle is white and it glows blue this is normal if blue is to intense you may have to adjuste your focus block
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
On the monitor below the screen has these fine pink and green lines blinking across the screen all the time on my laptop. Can you tell me how to fix it or solve this problem?
Sounds like the green is out of focus.
If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube.
On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus.
Hope this helps.
