I am having problems installing my EPSON LX-300 printer.i dont have any disc or floppy disc to install it cause i alredy miss placed it.please help me solve this problem.
You can follow the steps below to install a resident printer driver which is part of your operating system.
NOTE: Windows should detect and automatically install devices attached via the Parallel or USB ports on the computer. You should be able to attach the printer, and the "Plug and Play" feature will install the appropriate driver.
If the driver does not automatically install, please contact your Computer vendor. The "Plug and Play" feature may be disabled within your computer.
The resident driver installation should only be used if the printer is not detected and installed.
1. Start by opening the "Printers and Faxes" window. Click on "Add Printer" on the left hand side of the screen.
2. The "Add Printer Wizard" screen will come up. Click on "Next".
3. At the "Local or Network Printer" screen, select "Local Printer" and place a check on "Automatically Detect and Install my Plug and Play Printer". Click on "Next".
4. Windows should report it will check for Plug and Play hardware. It should also detect and install the appropriate resident printer driver.
5. A window will appear and tell you when the process is completed.
*NOTE: If Windows does not detect your printer automatically, you can manually install the printer. Simply select EPSON under manufacturer and select your appropriate model under PRINTERS.
6. When the printer is installed, it will ask you if you would like to print a test page. Check "Yes", then click on "Next".
7. The next screen will display the settings for the printer. Click on "Finish" to complete the installation and print the test page.
Sir,
I want to install my EPSON LX-300+ to my computer but i dont know what to do. Pls healp me
thanks
myla
I have a problem when printing under DOS printing when Im using FX 2175. The printer cannot print directly. How can you help me solve this problem ?
Go to epson site and download driver for your printer and then you can install your printer cheers scat
Along with the solution given by the other expert, try these also. If your operating system is windows xp system will automatically detects your printer. If you are using win 98 go to www.drivers.com and search. there you can get a set of drivers for your printer.
Download driver from epson.com site
SOURCE: problems installing a printer
How do you connect it to your computer? What type of cable?
check this link it will give you info if its compatible with vista
EPSON
But you can also use the generic text only driver from vista
Go to control panel
then printers
then add a printer(local), choose port (the type of cable)
manufacturer Generic, Printer generic text only
then click until finish and that should work.
tell me if you encounter an error or something
what is your operating system? If you have windows XP or Vista, you dont need to download anything from Epson. Just go to your start menu and look for control panel. In control panel, open "printers and faxes" or "printers and other hardware" then "printers and faxes". Once you are in "printers and faxes" click Add Printer...
An "add printer wizard" will appear in a new window, click next...
On the next screen, choose local printer. And make sure that the option "Automatically detect and install..." is selected. It will start searching... If the wizard did not find the printer, it will come up with a list of manufacturers... From this list choose EPSON and a list on the right side will show you the model names. Look for the LX-300 on the list, it should be there! Install it and you're done... The driver is already included in the windows operating system. You dont need the disc if you have Windows Xp or Vista....
Please help me instal my epson LX-300 printer
i tried a few suggestions here on your site but still cant install printer
yes. Ipurchased a new tower and do ot have the installation disc to install my epson cx3810 printer. please help
i have lost my instalation disk for my epsonc42+ stylus printer. where do i go to download one for free?
had problem with computor put back to factory settings printer now wont work cant find disc to install
i cant find my printer installer..how can i install it using the internet?
yes lost disc cant install
favor enviar los drivers de la EPSON LX300 no puedo instalar la impresora me pide los driver y no los tengo
por favor envienmelos les agradesco
envienme los drivers de EPSON LX 300
