Well if the fan is runing at top speed I dont think you have a bad fan, if you re-pasted the CPU correctly (I suppose you cleaned the dust build up in the heat radiator as well) since you had it in your hands... I dont think it's radiator dirt, and if the system POST (Power On Self Test) an can boot in to the OS (Operating System) I don't think it's the CPU either... The only thing I could think of is a power supply issue, try an other one, or a bad component RAM, PCI CARD, ETC... (but befor spending money) unpluge averithing you can leaving just the power, CPU, RAM and start the computer, if it POST and the fans are at a normal speed, than power down the computer and plug back stuff ONE AT A TIME to determine which of the components is causing the problem, if not sucsessful than try an other power supply or other RAM modules...
Cheers!
