I'm using Belkin Surf N300, i have 2 laptop connected to internet all the time. The problem is, its working properly only if one of the laptop connected in safe mode with networking support.
hi thanks for the advice, i tried all that before the post. something wrong with the firmware i think. i decided to change the modem,hi thanks for the advice, i tried all that before the post. something wrong with the firmware i think. i decided to change the modem,
You can't post conmments that contain an email address.
All configuration can be done with the router GUI. Firewalls: Server Side
Having a server side firewall is the typical configuration on many systems. There is only one method for doing this, whether
you use telnet or ssh: map a port to be forwarded to the server in the firewall router. It is not advised that you use telnet
from the Internet for security reasons; that is usually why you have a firewall.Decide which method of connectivity will be allowed, and determine
what port you will use to forward to this service. If there
is only one server involved, you can use port 22 for ssh or 23 for
telnet and forward them straight through to the server. But if
there are several servers involved and they do not have public IP
addresses, you will need to pick different ports on the
firewall router and let the router forward those ports to the
different internal servers.
There is a small piece of paper underneath the router with original passwords, and the default was WPA security. Hold the reset in the back till it cycles to remove any custom settings.
Being that your other computers in the network are working properly, you should switch the ip settings on your comnputer to automatically detect. That way your computer does all the routing and ip setting,
After you have set that back. Remove the power of your router, remove the power of your modem, and restart your computer.
Once your computer is back up, turn on modem, then the router.
It sounds very simple, but in most cases, it solves the problem.
Hi, let me know the operating system of your laptop or desktop that you're using (it's very
important for compatibility) and also the service pack that's running your PC. If you don't
install the adapter properly, the problem will occur repeatedly. Remember, running the
driver without plug in USB.
Have you ran one at a time to see if each one can connect by itself this would rule out a problem with one of your laptops.if you try this let me know. Thanks.You can call support at Belkin an they might be able to walk you through the setup.
When there is limited connectivity check if the laptop gets an IP address from the router. ELse try configuring it manually. Restart the laptop if necessary.
