SOURCE: driver's door won't unlock with remote
This may be a problem with wiring. I will need to know what the make and model is of the car. Also keyless entry system stock OEM or was that an option you have added? Lastly, did you install this system or was this installed by a cetified DEI corperation?
Thank you,
Luis
SOURCE: my car start on is own.
Sounds like you have it set in timer mode. Click on the following link for the manual---------> Click on the following link for the manual---------> http://www.directeddealers.com/manuals/og/viper/G564V_07-05.pdf
the manual should explain how to exit timer mode.
Hope this helps,
Luis
SOURCE: viper remote starter
Sounds like the tach connection has been loosened or slipped out of position. Here is a link for installation manuals, Will help in location and inspection of tach wire.
http://www.directeddealers.com/manuals/ig/viper/N5501V_12-06post.pdf
SOURCE: No install instructions
email me at [email protected] and i will give them to you. i 've been doing install professionally for 10 yrs and have access to directechs (DEI technician website)
SOURCE: I have a viper 5900 car alarm installed with remote start.
Look under dash for a small black box with wires coming out of it, about 2 or 3 inches rectangular.. there should be one or two screws on it. Look to see if it says which direction to turn for sensitivity. As far as not receiving, you need a new antenna, this is covered under warranty through DEI either bring back to where you purchased or look online and see where the closest dealer is to you...
