If the control circuit turns on the power supply to the magnetron tube, the big power transformer should hum. Then after a couple seconds, it should hum louder as the magnetron warms up and starts to put out RF. If everything stays stone cold, the magnetron is probably shot.
These are repairable, and the parts are available. But you have to decide whether it is worth repairing. If it's past warranty, probably not. I am a radar transmitter engineer with 40 years' experience with these kinds of tubes, and if my ten year old microwave quits, I'm going to just throw it out (after I take it apart just to see what quit).
It's probably the internal fuse.You will have to take the microwave down so you can remove the housing to get at the fuse.(I will probably install an accessable panel mounted fuse holder if this ever happens to mine-already did it on the little microwave I carry around on my work truck to heat up my lunch).
if microwave is counting down but no heat you either have a loose connection at the magnatron tube or the thermal cut out fuse that is connected to the magnatron has blown or you have a micro switch, that has failed
When a high-voltage capacitor fails,
it almost always shorts, which will cause the fuse to blow as soon as
you hit "start" to begin cooking. So you can almost certainly rule that
out. A loud buzz, hum, or groan is usually a
shorted high voltage rectifier diode, but a sound like gurgling into an
empty coffee mug is one symptom of a failed magnetron, and yet the mag can
be bad without that sound.
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
You can find exploded views and order parts by entering your model number at the Sears parts site.
There
may also be a "mini-manual" (tech sheet) hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
hi, You may need a new magnetron, contact sharp or the store you got it from; most microwaves have a 3-5 year warranty on the magnetron. If it's not in warranty, find a good appliance repairman, this is a difficult and dangerous repair job.
