If you are installing a wax (doughnut) seal to connect the toilet to the main drain, then the wax ring should be big. It should 'squish' to seal correctly. You may not need it, but I've known plumbers to install two of the seals at once for extra gap-filling. Just install the seal, sit on the toilet to compress the seal into place and then install the bolts to the floor. Done!
SOURCE: Installed a new Kohler model
2 possibilities.
1) The diaphragm in the Sloan is for a urinal. (1.0gal vs. 1.6gal);
2) Not enough water. (stop partially closed, supply undersized)
SOURCE: LOOKING FOR GASKETS & BOLTS BETWEEN TOILET & FLUSH BOX
go to any howm center, plumbing section. The replacement gasket is not the same as the original, however, they do fit. The other choice is go to Kohler resaller.
SOURCE: Toilet on uneven floor
I believe that I qualify... over 300 toilets installed in the past 15 months!!
I would go with the wax rings... but I would press the ring into the base of the toilet before installing the toilet....that way you are sure to have a good seal to the toilet....
If you actually read the directions, the manufacturer will tell you to press the wax ring onto the toilet....then install it onto the floor drain.
I guess that a PLAIN wax ring placed on the floor drain (since it is recessed) before placing the rubber-sleeve equipped ringed toiled is a good safety measure... I have done that an it work about 37 times out of 40.
Good question - BTW.. and well worded. THANKS for being specific and precise!!
Testimonial: "Sounds like a good idea. Not sure about the plain wax ring on the floor however. Doesn't this wax ring need a rubber sleave going into the drain?"
SOURCE: tiled bathroom floor. Went to install toilet
hi, the tile is supposed to go under the toilet flange (the thing you put the wax ring on), very common "oops", can be rectified by placing another wax ring right on top of the first on. best to make the first one a "horn type" wax ring, then put the plain one (no horn) on top of first and try to smoosh it on just enough to stay in place so when you install toilet it doesn't move,.....cheers!
SOURCE: How install Kohler part no. 87988 in Santa Rosa
look under the tank, their should be a nut holding on the old one. by removing that nut the part should free itself.
