Unable to disable parental lock to watch tv or change the channel.
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
I have asked this question myself : enter your parental code or try unplugging tv for 30 to 60mins then try again:
I have the same problem with my TV Daewooplus ST-1409S can anybody help me with the solution?
Press (SLEEP) button on remote handset & (MENU )BUTTON ON FRONT PANEL OF TV SIMULTANEOUSLY.
the tv receiver will enter in to service mode.
Btw, I learned this in a post by modern, so props go to to him.
BMW they dont use back up batterys any more in a tv set or at least the sets that Ive worked on. they use volitile memory mostly by way of an eeprom or built in eeprom in side the microprocessor. Just thought I would pass this on to ya.
Firstly, who set the paraental mode to on. To do this they must enter a code or password. Bring the menu display up on the TV screen and switch to Parental mode. It should ask you for that password. Enter it and unlock the set.. Another way which I wouldn't recommend unless you know your way around the innards of a TV set. Would be to find the battery backup inside the set, Remove it, go hqave a cup of coffee and then come back and reinsert the battery. You may have to retune the set but the parental control should be off. Does your set have a reset button somewhere on the back. If it does then it will do the same as removing the battery. As a last resort contact the manufacturer and ask them how to disable the problem. BMW
For all AKAI direct view sets: hold down "F" button on remote (top left button), and press mute. This removes the little red key from the OSD
I have the same problem!! Now we've lost the remote and my universal won't work with this crap tv. We have digital tv that currently I can only get 13 channels on and the big black box is in the middle of them all, and you can't get it off without the konka remote!! (ps if you hit the display button on the remote it temporarily disables it). My tv is pretty much unwatchable unles we're watching a dvd. I've contacted the company to no avail. No customer suppor whatsoever.
If you have a remote, press the (F) function key down and hold while pressing the mute button.
Chriss5563 is right...It worked...off for 45 then 2211
Thanks
Look at the screen. If you see a red key on the bottom of the screen,
press "Function" and "Mute" on the remote at the same time.
This will unlock the channel. Do this if you want to bypass the lock to watch a
certain show or channel while leaving the TV locked. All other channels will
remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by
entering 0711 or 3308. These are the Jensen factory reset codes that will reset
the TV to the original factory settings. By doing this, you will loose any
information that you have stored in the TV, such as channel labels and
schedules. You will have to program the TV again by going through the entire
initial set up.
•Call the technical support service number
in your owner's manual if neither of those codes work. A technician can help
you troubleshoot the television as the problem may not be the parental lock
feature. Have the model number and serial number of the TV available when you
call.
• Take your television to a TV repair shop if
neither of the codes work and the TV locked by itself while it was turned on.
In this case, the TV may need to be rewired
tv locked uo after fpa or something lock turned off wont turn back on
I can't get the God Dam parantal lock off the God Dam T.V and I don't know the God Dam password. I threw out the Sony control after it locked up my T. V. THIS IS 'ABSOLUTE SHIT. /
parental lock needs reset. It locked up my t.v. help
We lost the parental code. How do we reset tv?
tv locked
Forget my Parental controls
is lock my tv
i cannot get the parental lock disabled on this tv it sucks
the parental loke is on my tv and I do not have the remote how do i turn it off?
rca 27" tv dont have original remote/ fpa is locked and cant get to menu
Hey Everybody, it took me a while to get this issue sorted out, but i finally have the solution for those of you who dont have the original remote anymore, atleast for my model, it may work for you aswell. heres what i did: Turn the volume all the way down to 0 using the buttons on your tv. Then once its on 0, hold the volume button down (button on your tv, not remote) and while your holding it down, hit the menu button on your universal remote about 3-4 times in a fast manner, this will cause the TV to go into "self check mode" it will test itself, then you will need to unplug the TV. Once you turn it back on, it will be clear and you will get to setup the tv just like you would fresh out the box
KONK TV KL26GT611 ( HAVE PROBLEM) FROZEN ON USB MENU ) i dont have anymore remote from TV ... HOW I CAN FIX FROM FRONT PANEL?
trying to run auto scan and TV has locked up. Unable to run scan, unable to exit
Konka k2166sz CRT TV service code
