SOURCE: im looking manual instructions for coleman Sahara tent
Go on youtube, you will find some excellent videos on how to....on a range of tents. I saw the coleman sahara tent on a video last year as I was considering buying one! Good luck!
SOURCE: Instruction to put up a Coleman Rock Springs 4 Tent please?
Wow, thats a monster tent. I'll get you most of the way there, but I may miss a thing or two
Lay it down, stretch it out and peg it. That will save you a ton of time.
Next, find the four longest poles. These are the supports. Two on each side of the door, crossing diagonally to the rear. Put one end of the poles in the holes and bend until you can get the other end in. These poles should slide through sleeves in the tent. Once these are up, the rest are "extras." The tent has hooks to hold the poles to the tent.
You have two poles of equal lengths for the side windows. Again, route them thru a sleeve, bending them into the holes on either side of the windows. I can't tell, but it looks like you have a pole system for the front door too. Somehow these poles go next to the main support poles and meet up under the rain cover.
Next, lay the rain cover on top of the tent. It should connect by bungies to the bottom of the pole support holes. There might be a pole or two under the rain cover, but above the tent for support. If so. look for a small pouch that a pole could slide into on the bottom side of the rain cover. You'll run the pole from the pouch to another pouch (all under the rain cover).
Don't worry about strings or extra poles. These are for high wind. Pegging the tent down is good enough.
Good luck
SOURCE: I need my zipper replaced on my coleman tent. Who
I need my zipper replaced on my coleman classic tent. Where can I take it to get it replaced? I live in Phoenix Az.
SOURCE: coleman salt lake tent 9 man no instructions please help?
the instructions are useless anyway. you put the red poles through the 2 side bedrooms. the black rods and the black poles with the bends in join together and go diagonally through the middle of the tent. the yellow rods join together with the black poles with the yellow tape round the ends and u fit these from the inside of the front and back entrance then when the tent is up you just hook the bedrooms in. hope this was usefull
