Replace the optical engine. See my tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine for help with getting a new one and installation.
Thanks for using FixYa and for the great rating.
hardrocko
The DMD Chip needs replaced. Buy it through Amazon.com for $169. New Samsung/Mitsubishi/Toshiba 4719-001997 DLP Chip by Samsung Go to the following link for a video on how to replace it. http://m.youtube.com/#/watch?v=K7Jex2iJKvM The above will get rid of the white dots.
SOURCE: White dots on screen of 50 Samsung DLP
Random dots or pixels failing on a DLP TV will be a bad DMD chip. This is a technician replace item only. The chip runs around 160 dollars list price. The part number will depend on which version the set uses and will be determined by the technician.
SOURCE: White dots appearing on Samsung TV screen and multipling each day
It seems you might have an issue with the dmd board. Go to the menu, and if the dots still show on the menu, the issue definitely is with the dmd board but if they don't come up on the menu, the issue will be with the video board.
SOURCE: Numerous white spots on Smasung DLP TV
If your Mitsubishi TV has white spots in the picture , you can call Mitsubishi @ 1-800-332-2119 and request a free DLP Chip to fix the problem. They will send the New DLP Chip at no charge to a TV Tech in your area to install it for $200 flat rate. That is about a $250 savings if you had to pay for the chip . Call them with your TV's Model number and serial number and let them know when and where you bought the TV.
It saved me some hard earned money and now my TV is like New !
