I have a picture problem.
Hundreds of Blue dots all over screen but centre of screen looks like a cleaned window.
Have just replaced Bulb and prior to that screen was blue at edges.
projection tvs can display white dots from the dust that is on the reflector mirror your lamp shines the picture on before it is reflected onto the front screen of your tv, one must be very careful when cleaning this, may be worth a service man doing it for you
I just changed the lamp bulb. Why do I get a blue screen on the
I just changed the lamp bulb. Why do I see a blue screen on my Panasonic PT-43lc14. See photo. attached.
Your tv is an LCD projection one - in which the image is generated by 3 small LCD screens. The blue dots are pixels from the blue LCD that are dead - always fully open.The only fix is to replace the LCD panel and that is going to cost you around $300.
Yes,it is repairable.Blue dots on screen is sign of LCD failure at optical block assembly. There are three LCD on the optical assembly RED,GREEN and BLUE. Blue LCD failure causes blue dots on screen. Repair should be done by replacing blue LCD. Note! LCD replacement needs Extra care and precise tools such as oscilloscope and color pattern generator , for the color alignment after replacing LCD. But if you can afford, replacing the optical block is better,
my sony is 4yrs also it has blue dots on the left side from top to bottom and a blue blob on rt. bottom corner no longer under warr. please send repair solution.
