The machine (286) was shut down properly. The next startup POST would not recognize a hard drive. I ran several checks and at power on the hard drive would spin up and after a few seconds would spin down at which point POST will chech for a harddrive and - zip. Any suggestions would certainly be appreciated.
Walter
Hi walter, that usually means the first few sectors are bad(they are the important ones) or, the drive has a faulty motor/ is drawing too much current. There are two things to try. if you have a CDrom drive then boot a clean OS eg windows 98/XP from cdrom, or whatever os you were starting on that drive. you might then be able to access the hard drive from the command prompt or from the windows os on the cd in which case its just a few bad sectors that may be repairable by diags. Alternatively download burn and then boot a Hard Drive Diagnostics disk such as Hitachi(IBM) DFT. see it here the 2720K image https://www.hgst.com/support/hard-drive-support/downloads/legacy-downloads run a quick test and that will definitely indicate the true problem.
SOURCE: My Computer does not show: Western Digital My Book Essential Edition 500 GB external USB hard drive
Try freezing it. It sounds crazy, but hear me out... When I got the advice to freeze it, they said freezing also works when a drop causes premature crashing due to hardware failure. I'm a novice, but know enough to be dangerous, so I scrounged the internet trying to find a fix when this happened to me two weeks ago. Mine didn't fall, but started clicking due to hardware malfunction. I was devastated because of course I was too dumb (and cheap) to buy a second hard drive to back up the data on my first one. Lesson learned. Anyway, data recovery was 3 grand or more and I can't afford that so I took the advice of a bunch of people and tried the crazy idea of putting the dumb thing in the freezer. I took the case off using instructions I found on the web and then wrapped it in a white flour sack cloth to absorb moisture and put it in a ziplock in the freezer. After 24 hours freezing I tried again, nothing but obnoxious clicking. Going into Control Panel/Administrative Tools/Computer Management/Device Manager I could see the drive but it said there were no partitions. Windows Explorer wouldn't assign a drive letter. I threw it back in the freezer for 10 days and on a whim last night tried again. The USB 2.0 port on my XP computer is broken and everyone told me not to use Vista if I could help it. So I took a USB hub and plugged it into my USB 1.1 port and then plugged the new hard drive in first and let it boot up. Then I took the frozen hard drive and plugged it in too and I was SHOCKED when Autoplay started running. Maybe the drivers and software from the good drive allowed the bad one to boot up. I don't know. I just know that it didn't work plugged in directly to the USB but it did via the hub good drive first.... Anyway, I have cords running out of the freezer into my laptop which is perched on a chair outside the freezer. I got all my pictures and priceless data off this drive overnight. It did stop a few times (says it can't find the file and the drive stops spinning) and I was able to unplug it, plug it back in and get it going again. It is SLOWER THAN MOLASSES and I would strongly suggest prioritizing your stuff so you get the most important data first because you don't know how long it will run, but I am thrilled beyond belief I got my pictures and home movies back. People told me I was crazy and stupid for freezing a hard drive, but it worked for me so I'm not going to question it. My data is on the new hard drive which I am immediately going to back up onto a second and I will live happily ever after because I didn't need to spend thousands to get my data back. Good luck!
SOURCE: Quantum Fireball Lct20 20 GB
Appreciate the direct "Ask Me".
A 20Gb Quantum Fireball LCT20 could be nearing its life end considering the length of time it has been in service. Perhaps what could be done is to perform a burn-in test on the 20Gb HD attaches as a Slave or Secondary on a 2nd PC or alternately, as an external mass storage device through an IDE to USB adapter. Burn-in test would be a multiple time scanning fro errors as those used by Norton Disk Doctor. Alternately, you can also Partition Magic to partition/format and eventually test the HD.
In your concern of PC slow down after 10 minutes, it is possible that:
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: Western Digital 500gig External Harddrive. Power up troubles.
this is a bit tricky , you'll need to tell my what operating system you have ,
more than likely sounds like windows power management is turning the drive off
check your power management settings.
if thats not the case just let me know.
shalom
SOURCE: new hard drive not recognized on my mac
I figure it is a compatible drive (eg, either a PATA or SATA drive, depending on what your Mac uses). I don't know a whale of a lot about Macs, but I know that when you add a second hard drive, especially if you are using a PATA (uses the wide ribbon cable), one drive needs to be jumpered and cabled as "master", and the second drive as a "slave". If the XP drive was the only one in the box, it was likely jumpered as a master.
How to fix it? Look on the drive itself, and it should have a small diagram telling you how to set the jumpers (usually located next to the power connector on the drive). Set the add-on as a slave, and give it a whirl.
Also, don't be surprised if you have to re-format the drive. I doubt that a Mac uses a Win compatible structure.
Cheers
Nick
SOURCE: hard drive not recognized
hi I am using Hitachi external hard disk with aluminum case. When I connect my hard disk with my PC it is not recognizing my hard disk. I want retrive my data from the hard disk please let me know the solutions.
Thanks,
K.Venki
