Question about RCA Scenium D40W20 40" Rear Projection HDTV
At first would take about 10 minutes of pressing the tv button on remote for the tv to come on. The green light on the power button on tv lights up and goes of in a sequence of three times, waits about a minute and starts lighting up again. While this happens I am pressing the tv button on remote. Now tv will not come on at all. It is also hooked up to surround sound. We can hear tv but no picture.
  • 1,476 Answers
See my tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting for help with troubleshooting.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Sep 07, 2011
6ya staff
SOURCE:
I have a Mitsubishi WD 60738 and the stand by light on the front of the tv was staying on and was orange. I removed the power supply and blew out all the dust and reinstalled the power supply and now the...
Hello Jeff;
If the TV does not turn on or off, does not respond to the remote
control or the control panel buttons, or has audio but no video:
1.) Press and hold the POWER button on the control panel for ten seconds. The TV will turn off.
2.) Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost.
If the TV does not respond to the remote control or to the control-panel buttons and TV will not power on or off.
• Unplug the AC power cord for 10 seconds.
• Press and hold the POWER button on the control panel for 10
seconds to perform a system reset.
If the TV turned itself off and the light on the front panel started to flash:
• Momentary power fluctuation can cause the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again.
• If the TV does not stay on, press the POWER button on the
control panel for ten seconds to perform a System Reset. If this happens frequently, obtain an AC line power conditioner/surge protector.
• An unusual digital signal may have been received, triggering a
protection circuit. Wait for the light to stop flashing and turn TV
on.
If the TV will not power off, press the POWER button on the control panel for ten seconds to perform a System Reset.
Should you still have problems, call for assistance at 1(800) 332-2119
I would not recommend using compressed air or any other method that would blow dust around- since the dust could make its way into the set's circuitry via the grille or vents and cause problems. Use a vacuum cleaner with a brush attachment instead.
Mar 12, 2015 | Mitsubishi Televison & Video
Program code for Directtv Universal remote.
You can see an easy step-by-step guide to programming your remote right on your TV screen:
sm_cl_blu__number1_icon.pngPress MENU on your remote control sm_cl_blu__number2_icon.pngSelect Settings & Help sm_cl_blu__number3_icon.pngSelect Settings sm_cl_blu__number4_icon.pngSelect Remote Control sm_cl_blu__number5_icon.pngSelect Program Remote and follow the on-screen prompts img_remote_control_tv_sol1.jpg You can also use the manual method below: sm_cl_blu__number1_icon.pngMake sure your TV and your receiver are both on. sm_cl_blu__number2_icon.pngUse this tool to look up the 5-digit code for your TV. There could be more than one code for your brand of TV. sm_cl_blu__number3_icon.pngSlide the MODE switch on your remote control to the TV position. sm_cl_blu__number4_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number5_icon.pngUsing the number buttons, enter the 5 digit code for your brand of TV. The green light under the TV should flash twice. sm_cl_blu__number6_icon.pngAim the remote at your TV and press the VOLUME UP button. If the volume doesn't increase, repeat Steps 3-5, trying a different 5-digit code for your TV. If your remote control fails to program using all available codes, try scanning for additional codes. If one of the codes worked, proceed to the next step. sm_cl_blu__number7_icon.pngPress and hold MUTE and SELECT buttons until the green light at the top of your remote control flashes twice. sm_cl_blu__number8_icon.pngEnter 9-6-0 using the keypad on the remote control. The green light should flash twice again. sm_cl_blu__number9_icon.pngSlide the MODE switch on your remote control to the DIRECTV position. img_remote_control_tv_sol2.jpg Follow these steps to scan for additional TV codes using your DIRECTV remote: sm_cl_blu__number1_icon.pngSlide the MODE switch on your remote control all the way to the right to the TV position. sm_cl_blu__number2_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number3_icon.pngUsing the number buttons, enter 9-9-1. The green light on your remote should flash twice. sm_cl_blu__number4_icon.pngAim the remote at your TV and press CHAN/PAGE UP button. Tap the CHAN/PAGE UP button repeatedly until the TV powers off. sm_cl_blu__number5_icon.pngWhen the TV powers off, press and release the SELECT button. Note: If the green light flashes three times before your TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, but your TV may not be compatible with our remote control.
Jul 08, 2014 | GE JASRM24912 Remote Control
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
My Samsung 20" CRT model # TX-P2036 has power
May be you should press the channel button on the set itself or there is a problem with the eeprom of the set circuit.
Jun 15, 2011 | Samsung TXP2036 20" TV
Can set up th remote control for this tv with the direct tv cable remote
Here's how to scan for TV codes on your DIRECTV remote
1.Make sure your TV is turned on.
2.Slide the mode switch at top of remote to "TV".
3.Press and hold the MUTE button. This is located above the number 1 button.
4.While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
5.Then enter 991, the green light on remote should flash twice.
5b. Press 1 again (it will flash twice again), then you press the power on button at the very top right.
6.Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
*If you hit channel up very fast, you risk going past the code. Pressing channel down will back it up. I alway hit channel up very fast till the tv turns off, then back it up slowly till it comes back on.
7.When the TV powers off, press and release the SELECT button.
*Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
Mar 05, 2011 | Curtis LCD2425A TV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
How to program philips universal remote
  • Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control.
  • Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
  • Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
  • Press the "TV" button on the remote to program the Philips remote to your television set.
  • Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television
  • Dec 04, 2010 | Philips Televison & Video
    Need rca crk17sa users guide for codes for Magnavox TV
    Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
    http://www.directv.com/DTVAPP/content/remote_codes
    Here's how to program your DIRECTV remote control:
    1. Press MENU on remote.
    2. Select "Parental, Favs and Setup"
    3. Select "System Setup"
    4. Select "Remote"
    5. Select "Program Remote"
    While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
    How to program the white DIRECTV remote to your TV
    1. Look up the control codes for your DIRECTV remote control.
    2. Make sure your TV is turned on.
    3. Slide the mode switch at top of remote to "TV".
    4. Press and hold the MUTE button. This is located above the number 1 button.
    5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
    6. Enter the first TV code you have. The green light on remote should flash twice.
    7. Aim remote at TV and press PWR button once. The TV should power off.
    8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
    If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
    If remote control fails to program using all available codes, try scanning for the code.
    How to scan for TV codes on your DIRECTV remote
    1. Make sure your TV is turned on.
    2. Slide the mode switch at top of remote to "TV".
    3. Press and hold the MUTE button. This is located above the number 1 button.
    4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
    5. Then enter 991, the green light on remote should flash twice.
    6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
    7. When the TV powers off, press and release the SELECT button.
    Mar 08, 2010 | Televison & Video
    Green light blinking
    The green light on the front blinkes and does not stop even after hitting re-set button.
    Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
    RCA Scenium D40W20 40" Rear Projection HDTV Logo
    103 people viewed this question
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
