Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
Ram cleared, how to reset ram memory - Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
  • Texas Instru... Master
  • 8,081 Answers
If the calculator says RAM Cleared, then the RAM is cleared and there is no need for you to reset it. again.
If the calcularor says RAM Cleared everytime you turn calculator on, it may be due to a depleted backup battery.
Posted on Dec 17, 2011
Ti 83 will not power on replaced all batteries
When you clear memory, the contrast sometimes changes. If the screen
is faded or blank, adjust the contrast by pressing 2nd and up- arrow or down- arrow keys .
Resetting RAM restores RAM system variables to factory settings and
deletes all nonsystem variables and all programs. Resetting defaults
restores all system variables to default settings without deleting variables and programs in RAM. Resetting RAM or resetting defaults does not
affect variables and applications in user data archive.
Tip: Before you reset all RAM memory, consider restoring sufficient available
memory by deleting only selected data.
To reset all RAM memory or RAM defaults on the TI-83 Plus, follow these
steps.
1. From the RAM ARCHIVE ALL menu, select 1:ALL RAM to display the
RESET RAM menu or 2:Defaults to display the RESET DEFAULTS menu.
2. If you are resetting RAM, read the message below the RESET RAM
menu.
• To cancel the reset and return to the home screen, press .
• To erase RAM memory or reset defaults, select 2:Reset.
Depending on your choice, the message RAM cleared or Defaults
set is displayed on the home screen.
Mar 25, 2012 | Texas Instruments TI-83 Plus Calculator
steps.
menu.
How do i reset it?
Press [2nd][ ] to open the memory management tool
Select [7:Reset]
Enter 1 select [1:All RAM]
Enter 2 to select [2:Reset]
Press [ENTER]
Calculator will answer "RAM CLEARED"
Press any key to clear the message.
Sep 21, 2010 | Texas Instruments TI-84 Plus Calculator
I cannot get numbers to show up. a checkered pattern light shows up
The checkered cursor means that memory is full. You must clear it or reset it.
Press [2nd][+] to access the (MEM)ory management function.
Select [7:Reset][1:All Ram][2:RESET] [ENTER].
Press [Clear] to clear the "Ram Cleared" message.
If that does not work, remove the main batteries for a while and resibsert them.
Mar 24, 2010 | Texas Instruments TI-83 Plus Calculator
Why won't my calculator type it's just the screen and the marker. won't even turn off by itself just on and does nothing.
If cursor is a checkerboard rectangle that means the memory is full. Memory must be cleared or at least some space freed.
Press [2nd] [MEM][7:Reset][1:All Ram][Reset].
Press [CLEAR] to erase Ram cleared message.
If some third-party program or game is stuck in memory, it should be kicked out of memory.
Dec 15, 2009 | Texas Instruments TI-84 Plus Calculator
The calculator will not work and won't let me type anything. The only thing on the screen is a cursor and it is not blinking.
What kind of cursor? Is it checkered? If it is the memory is full that is why you cannot type anything anymore.
  1. Delete games,
  2. clear all lists [2nd][MEM][4:ClrAllLists][ENTER.]
  3. Clear entries [2nd][MEM][3:Clear Entries][ENTER.]
  4. If that is not enough reset Ram [2nd][MEM][7:Reset][1:All Ram] [2:Reset][ENTER]. Clear the Ram Cleared message.
Hope it helps
Dec 04, 2009 | Texas Instruments TI-84 Plus Calculator
Gives error memory message when tries to change
See if the cursor is checkered. If so, the calculator is out of memory.
You may have very little memory available and then wanted to create a table with a very small DeltaTbl (the table step). If the step is small, and the domain is large, very many points will have to be generated and that may make the calculator unable to comply for lack of RAM.
I suggest you free some Ram by clearing the lists, clearing the entries. To do so you press [2nd][MEM][3:Clear Entries] to clear entries, then press [2nd][MEM][4:ClrAllLists] to clear the lists.
Alternatively, you can just reset the Ram by pressing [2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER]. Then clear the Ram Cleared message and start again your table.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Dec 01, 2009 | Texas Instruments TI-84 Plus Calculator
The cursor blinks as a checkered black square and keys don't work
The memory of the calculator is ful,l that is why you cannot enter anything anymore. You must clear the RAM of the calculator.
Press [2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER]. Press CLEAR to clear the Ram Cleared Message.
If that does not work, pull the main batteries out of calculator and leave them out for a while (a few hours). Then reinsert them.
Hope it helps.
Thank you for using FixYa and rating the solution.
Dec 01, 2009 | Texas Instruments TI-83 Plus Calculator
Random symbols and/or dots all over the screen, cursor in middle of screen an turns off randomly
1. Press [2nd][QUIT] to interrupt any program that may be hung in memory such as games run under MirageOS.
2. Clear the screen by pressing [CLEAR].
3. Reset memory [2nd][MEM][7:Reset][1:All Ram][2:RESET] [ENTER]. ram cleared appears on screen.
4. Press [CLEAR] to go to Home screen.
Hope it helps.
Sep 30, 2009 | Texas Instruments TI-83 Plus Calculator
Err: memory every time i try to perform a function this message pops up
The RAM may be full, especially if you ran some programs on Mirage OS.
Reset all Ram as follows.
[2nd][MEM][7:Reset][1:All ram][2:Reset] {CLEAR] the Memory cleared message.
Hope it helps.
Aug 12, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
1,032 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Ekse
Paul Bade
Edward Easley
Edward Easley
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
