Pull the unit out from the wall and unplug it. Remove the back panel and check the counter weight (looks like a cement quarter round cement block), spider pulley and belt. The counter weight is attached to the top of the drum and can loosen and fall to the bottom damaging the spider pulley. If the counter weight is firmly attached to the top of the washer drum and the belt is attached to the spider pulley and motor, remove the top cover and lower front panel. Check to make sure the drum springs and shocks are attached to the drum. I hope you only need to bolt the counter weight back on and no other damage to the machine is found, you should get bake to business in about 40 minutes.
