Question about E-Machines eMachines Desktop PC
Emachine crash we had a power outage and my pc will not even allow us to go to the boot screen. The hard drive is making a beep every 2 seconds. Is the hd dead? Thanks a million! Lee
  • leethedad Sep 13, 2008
    thank you for your help. I rechecked the pc and made sure everything appeared to be plugged in correctly. I had the pc unplugged for a while as well. The beeping has stopped and the e machine symbol has reappeared, but it will not allow me to input using the f8, f2, or f 10 buttons. Do i have any other options or is this pc done for? Thanks again, lee
    The delete key did not work either. The os will not start up....
  • 6,487 Answers
Yes, with that beeping sound that you're hearing from your hard drive is a sign of a bad hard drive , that's also the reason why the computer wont even boot because the hard drive is already bad, the best thing that you can do here is to get a new hard drive..
Hope that helps..............
Posted on Sep 12, 2008
  • Mark Gil
    Mark Gil Sep 13, 2008
    Try to reboot the computer then press DEL key on the keyboard....
6ya staff
SOURCE:
Power light flashes but PC will not boot up following power outage
First off: Protection is important and the ONLY way to go is with a UPS (Battery backup protector). These devices allow the computer to SLOWLEY close down and protect the motherboard and hard drives. Simple bar protectors are of little to no use whatsoever. As for the Start UP; the Boot Sector on the Hard Drive has been compromised. If you attempted to start with the F8 key when you started up the computer and failed to Boot in the Safe Mode, you definitely lost the operating system.
You can try to do a Restore, but that may not be effective.
When a Computer starts, there is usually a Beep (called a Post) and one Beep indicates the motherboard is active. Several beeps indicate a mal-function of the motherboard and it was damaged. In some cases, the Memory (RAM) can be damaged from electrical surge, and thus the computer will not start and the monitor will not be active. Do not touch the internal leads as they are not the problem. In closing, a CPU is very sensitive to power surge and the CPU in some cases can be defective. All in all, with so may options or repair issues; only a professional has the equipment to search for the solution. Good luck: DaytonComputerDoctor@hotmail.com
Dec 18, 2013 | Evesham Axis 64 3000+ (AXIS643000+MAR04)...
Power outage now my e machines el 1200 01h won't boot saying no boot file name revevied?
Try to enter your boot screen, usually by pressing F8 when booting up. Then go to your boot priority list and make sure it is booting from your hard drive. I'm not a fan of e machines, it is very possible that the power surge caused some memory or physical errors.
Apr 11, 2013 | E-Machines eMachines Desktop PC
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
I hear two beeps when i conect power suply on my emachine t5212 model
Very sorry about your son.
If you can't find the real problem, you can always put that hard drive into another PC to get the files. If so, be sure to looking to a potential "jumper" setting on that drive for it to be recognized.
May 05, 2012 | E-Machines T5212 PC Desktop
7/1/11 eMachine T6211 won't boot at all; no fan starting, monitor says there is no connection and there is beeping that does not stop. Short beeps spaced evenly. Could it be bad capacitors? When...
Most probably is a RAM memory issue, those beeps are issued when a RAM module can not be found, may be the machine sufferend a crash an the ram jumped out of it's slot (less probable) or just broke (Most probably) certainly a tecnician can save your data to another PC or even, fix the broken PC by replacing the broken RAM module with a new one
Jul 02, 2011 | eMachines T6211 PC Desktop
I haved a Emachine EL 1300G-01W that has crashed
Power it down, pull the power lead out, remove the cover from the base and check that all the leads (to the hard drive and the motherboard) are seated correctly - by physically pushing them in. Then push and hold the power button on the front for 10 seconds. Then replace the cover and power lead and try starting it up.
Jun 05, 2010 | E-Machines eMachines Desktop PC
Power on emachine T6420 and moniter is blank. The moniter soon loses contact with the computer. The fan run and power is OK there is no beep code.
If you mean after the computer performs the self test the screen goes blank and stays blank, eventually turning off you are having a hard drive problem. When the computer boots you should see an E-Machines logo and/or a self test on the screen. That is done by the motherboard as part of every boot up. After that the motherboard passes control to your boot device and loads your operating system. If your computer stops booting at that point, your boot device is not working properly. That could be caused by many things - virus, hardware failure, power outage. If you really mean you see nothing at all on the screen when you press the power button your computer simply is not working at all. Open the case, blow all the dust out of it and reseat all components you can, then try again.
Jun 05, 2009 | E-Machines eMachines Desktop PC
Computer stuck on black screen from crashing
Make sure that your hard drive is set as first boot device and disconnect all the USB devices from the system and than try to boot.
Apr 21, 2009 | Computers & Internet
Won't boot up
Emachines are notorious for motherboards and power supplies frying after a power outage. Why? Even after 10 years of working on desktops from all manufacturers... this eludes me.
1)The power switching chip or chipset usually goes first. My best guess is be casue the power supplies in these desktops are VERY inexpensive. IT's amazing if they last longer than 1 year.
Replace power supply.. if doesn't boot still... replace motherboard.
2) If i'm waaay off and you get a boot screen or emachine logo.. but no windows logo... then hard drive crashed or file system got shot...
Replace hard disk and reinstall windows.. contact data recovery specialist. DYI data recovery .. causes more data loss... speaking from experience.
Nov 03, 2008 | Microsoft Xbox 360 Console
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
E-Machines eMachines Desktop PC Logo
137 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
