Did it possibly blow a fuse in the treadmill? Also, Check your circuit breaker as well, and see if a circuit blew that was dedicated to the outlet.
Read the user manual of your
treadmill to find the elevation motor. The treadmill fuses are located
inside the elevation motor. If you don't have the manual, contact the
manufacturer of the treadmill and ask if it can send you one or if there
is one you can download online.
Turn off the treadmill and unplug it. If you have recently used it, let it cool down for one hour before opening.
Place the treadmill on its
side and use a screwdriver to unscrew the lid off the elevation motor.
Carefully remove the fuses. Some treadmills have easy access to internal
parts where you don't need a screwdriver. If this is the case, simply
lift the lid off.
Take the faulty fuses to a hardware store to make sure you purchase the correct replacement fuses.
Insert the new fuses into the elevation motor and close the lid. Plug in the treadmill to see if it works.
